17-09-2007, 11:02 PM
die blizzard die! D3?
Dvi Or Vga!!
I was using VGA port(I dont know what its called exactly) of my monitor till now because my onboard graphics has only vga out but now I am buying a graphic card(8600GT) within 2 weeks.My question is which one is better VGA OR DVI?Will using dvi give me better picture quality?
Stealing your women and horses since 1843.
17-09-2007, 11:24 PM
The Frozen Nova
Re: Dvi Or Vga!!
DVI better coz the output is digital and there is no conversion involved i.e; there is a digital to digital transfer
VGA: Digital to analog and then analog to digital
www.nerdweed.blogspot.com
18-09-2007, 12:12 AM
Re: Dvi Or Vga!!
i was using a Dell 21" LCD with my 8800 and it was connected by DVI cable, the display was awesomely clear. about 15 days back my dog gave a jump to broke my LCD and i switched to my old 19" crt DELL, the display is now converted to VGA and its about 50% less authentic compared to it was before. ! so definately DVI is better .
18-09-2007, 12:17 AM
Re: Dvi Or Vga!!
Thanks for the replies.More reasons to love my 19' LCD monitor.
18-09-2007, 12:24 AM
Re: Dvi Or Vga!!
@shantanu,
What happens when an LCD breaks ? Are there glass pieces around..or some liquid comes out or what ?
By the way, give my love to the Dog.. and some biscuits.
18-09-2007, 12:27 AM
Re: Dvi Or Vga!!
lol ! no nothing happens as such, not even the front thing breaks or atleast didnt broke in my case. the screen had a spider like web created inside and when i plugged it there was only light flashing besides the screen. i kept it on coz it was like some hacker map or something and after 4 or 5 hrs. it said me good bye and gave a final whistle and went down
i already gave my god some biscuits  with love
18-09-2007, 01:12 AM
"The Gentleman"
Re: Dvi Or Vga!!
hey shantanu, is it possible to get some converter so tat i can cannot my 17" CRT monitor in DVI for better clarity.... ?
what would be cost of converter if available. ?
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
18-09-2007, 02:29 AM
Re: Dvi Or Vga!!
^^ I don't think so dude...
18-09-2007, 03:30 AM
Re: Dvi Or Vga!!
yeah its possible.. but you got-to spend about 850/- bucks to get the convertor..  (the DVi-> VGA ) there are two types.. one is normal and the other is a cpecial edition with extra display control and clarity features, it retains the clarity from DVi and provides you almost same clarity as DVi on a VGA i mean CRT monitor  i will post a link or a picture of a particular product... with brand make
18-09-2007, 06:42 AM
Re: Dvi Or Vga!!
I think all XFX cards are shipped with this type of converter.i.e.dvi->vga but I don't know how good are they.
What kind of dog you have shantanu?bulldog,shepherd?
18-09-2007, 09:43 AM
The Frozen Nova
Re: Dvi Or Vga!!
BTW, how much would a DVI cable cost. I plan to buy this Saturday. Sadly, I couldn't find one last sunday.
18-09-2007, 02:14 PM
Re: Dvi Or Vga!!
Dunno dude my Monitor was shipped with both vga and dvi cables.
18-09-2007, 02:36 PM
Re: Dvi Or Vga!!
dvi cables cost approx 650/-
i have a Boxer, pamerarian and a Himalayan Sheef Dog..
18-09-2007, 05:09 PM
The Frozen Nova
Re: Dvi Or Vga!!
Ouch, it hurt. I thought it will put me back by some 250 bucks. Shantanu, please suggest which 1 should I buy for my Viewsonic monitor
18-09-2007, 07:56 PM
Re: Dvi Or Vga!!
go for the DVI cable , you can get of viewsonic only, it will cost you 700/- and if you go for the normal makes, then also it is around 600 or 650/-
but there is always jugaard  , there is a cable made by intex it costs rs. 450/- so you can go for that too.. but if you need quality go for the higher ones.. and you will notice thedifference... The authenticity is just like WOW
19-09-2007, 10:01 AM
The Frozen Nova
Re: Dvi Or Vga!!
Thanks shantanu. I would go for quality. Will purchase viewsonic cable.
19-09-2007, 01:06 PM
Re: Dvi Or Vga!!
Hi Shantanu,
Can you tell about the make of the VGA to DVI connector?
19-09-2007, 02:29 PM
Re: Dvi Or Vga!!
XFX , Leadtek and a good but cheap solution is of Eyevision
