Old 17-09-2007, 01:15 PM   #1 (permalink)
Default laptop usb2.0 not working as per the rated speed.
Dont know what happened but seems that during last few windows update the USB2.0 ports had issues & are not working optimally on XP1+ updated SP2.
2 ports don't connect the devices or give errors, other 2 ports working but very slow data transfer, surely not usb 2.0 speeds.
I am thinking to format it at use a slip streamed CD with sp2 instead of my original.
Any other way I can get the usb 2.0 speeds back & all port working without errors, I was thinking I uninstall all usb devices & let XP detect them again, can that solve the problem?
ranjan2001 is offline
Old 18-09-2007, 02:36 AM   #2 (permalink)
Laptoping
Sourabh's Avatar
Default Re: laptop usb2.0 not working as per the rated speed.
Check the BIOS settings.
Sourabh is offline
Old 18-09-2007, 10:47 PM   #3 (permalink)
I checked the bios setting & even tried setting it at its default setting but the problem remains.
Old 19-09-2007, 06:47 PM   #4 (permalink)
Laptoping
Sourabh's Avatar
What abt Intel Chipset Software Utility..the INF one? (Presuming it's a Centrino-based one)
Sourabh is offline
Old 19-09-2007, 06:57 PM   #5 (permalink)
Wire muncher!
infra_red_dude's Avatar
can you boot into some Linux Live CD and check the usb port working/speed from there? that help you determine whether its a H/W or a S/W problem.
infra_red_dude is offline
HP Pavilion laptop camera not working vikasg03 Laptops and Netbooks 4 30-05-2008 12:22 PM
Google Rated Bottom For Privacy morpheusv6 Technology News 3 13-06-2007 01:04 PM
