Old 16-09-2007, 02:20 PM   #1 (permalink)
coolsunny's Avatar
Lightbulb Suggest a TV tuner card
hi guys,
I need a External tv tuner card. I am using CRT now but have a plan to buy TFT monitor in near future..So suggest me a good external tv tuner card which produce good pic & sound quality.It must be compatible with CRT & TFT.My buget is 1500.
AMD X2 260, GA M68MT-S2P, Gskill RipjawsX 4GB, 500Gb Seagate, Cooler Master eXtreme Power Plus 600W, Altec Lancing atp3, Samsung B2230 TFT, Numeric Digital 600 EX-C UPS.
coolsunny is offline
Old 18-09-2007, 04:49 PM   #2 (permalink)
coolsunny's Avatar
Default Re: Suggest a TV tuner card
No replies...wht happened .... suggest me a good brand u know..
Old 19-09-2007, 03:32 PM   #3 (permalink)
dissel's Avatar
Check Tech-Com SSD-TV-722 which is Digit "Best Buy Silver" winner in April 2007 TV Tuner shootout in External Segment.....
Digit quote the price Rs.1700/-,Hope this is now 1500/-
I bought it in May, and cost for me Rs.2000/- (icl vat).You can use it both LCD and CRT.
dissel is offline
Old 19-09-2007, 11:08 PM   #4 (permalink)
coolsunny's Avatar
thnx a lot for reply..hope i will get this tv tuner in market..
Can u tell me which one is the Best Buy Gold winner in April 2007 Digit??tell me its price too..
& any other opinioins...
Old 20-09-2007, 12:58 AM   #5 (permalink)
dissel's Avatar
^^^In External Segment AVerMedia AVerTV Box7 is the "Best Buy Gold" winner, Digit quote the price Rs.7500/-.
The Best feature in its class,Check the product page
According to digit,The Best TV Signal reception to all of them.
They somewhere said that it beats Internal/USB Segment too...in the field of Signal reception.
But it is too pricy.
This is the only card which support VGA-VGA connection,All other(Digit tested) have VGA-Din (Propwritery Cable), it not an issue though....if VGA-Din cable available in your place or you lost the original one.
One thing you remember you can't record the video/picture into your hdd directly from the card,This is the only drawback of these External cards.
dissel is offline
Suggest a vista ready tv tuner card spitfire Software Q&A 4 30-05-2007 03:21 PM
Suggest TV Tuner Card pannaguma Hardware Q&A 12 12-05-2007 01:02 AM
Suggest me a Best PCMCIA Tv tuner card symbiguy Hardware Q&A 2 03-04-2007 05:08 PM
SUGGEST GR8 T.V TUNER CARD mrintech Hardware Q&A 6 27-02-2006 01:27 AM
