Old 16-09-2007, 12:55 PM   #1 (permalink)
Default Compatibility...can i build this?
Planning to assemble a mid range gamerig
is the undermentioned configuration OK in terms of compatibility?
i am planning to build a mid range computer for myself for mainly gaming and CG applications.
i plan to incorporate the following components-
1. Motherboard and processor-
ASUS P5N-E SLI with Intel Core 2 Duo E6850, 3 Ghz or E6550,2.33 Ghz
or
Gigabyte GA-M57SLI-S4 with AMD Athlon 64 X2 dual core processor...preferably 6000+ or 5600+ if 6000+ is not available.
2. BIG GeForce 8600GTS 256 MB GPU.
3. RAM - Zion DDR2 667Mhz 1GB...two sticks initially and a later upgrade to four sticks if finances permit.
fieldgunner is offline
Old 16-09-2007, 01:12 PM   #2 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
Default Re: Compatibility...can i build this?
Go for intel based PC i.e
Graphic card and RAM is ok.
What compatibility dude?Everything is cool with your configuration.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 16-09-2007, 01:30 PM   #3 (permalink)
wondering about cpu-motherboard-graphicscard compatibility and interoperability...
but if it is ok then thanks!
ram compatibility rahul30 Hardware Q&A 7 10-06-2007 05:19 PM
RAM compatibility vish1988 Hardware Q&A 8 26-12-2006 11:20 PM
RAM compatibility Help d33p4k Hardware Q&A 14 07-03-2006 02:50 PM
DDR RAM Compatibility vinayasurya QnA (read only) 3 19-06-2005 12:31 AM
USB 2.0 compatibility anoopingenius Peripherals 1 15-11-2004 11:53 AM
