Old 16-09-2007, 02:12 AM   #1 (permalink)
d
Default Computer Turns off by itself
I put together a desktop from parts purchased today.. a P4 dual core 3.0 ghz, an MSI motherboard.. 1 gig ram.. and a PCI-E 8600GT video card. the trouble is.. when i boot it up.. it turns on, after a few seconds, turns off, and then turns on by itself again.. but there's no display. keyboard lights flash and everything.. cpu fan, gpu fan, everything spins.. but apart from that nothing.
There's this another PC i put together a few days back.. same proc, with micro-atx ASUS motherboard with onboard video.. it worked awesomely for a couple of days.. and now it won't turn on.. when i turn on, turns on for a bit and then shuts off.. two seconds it runs.. and then shuts off.. then it doesn't respond.. you've to unplug the power from the SMPS and plug it back again for it to even spin for the two seconds.. but after it turns off also the motherboard LED glows.. i've no idea what's going on.. i've tried everything literally..
The torquemaster rules.
d is offline
Old 16-09-2007, 02:27 AM   #2 (permalink)
shantanu's Avatar
Default Re: Computer Turns off by itself
have you tried to check thats the parts are assembled correclty.. and whether you SMPS is ok.. try another SMPS with higher wattage...
shantanu is offline
Old 16-09-2007, 11:52 AM   #3 (permalink)
d
I don't know.. i'm running a 350W SMPS on both computers... and one of those online calculator things show i need ~280W... so unless the quality of the SMPS itself is a prob..
d is offline
Old 16-09-2007, 01:07 PM   #4 (permalink)
shantanu's Avatar
a fact : you can read you manual too , now a dayz atleast a 400w PSu is must.. and you are using a 350 watt and your Comp. demands at least 280 watts..
lets make it clear : the SMPS these 350 watts are and so arent True power, they give max to max 5A or 6A on a 12V rail.. and it cannot get your system up and running.. i am sure and that too with a 8600GT naah not possible.. just get a 400 or 450 watt PSu and your comp will boot up.. i am sure now
shantanu is offline
Old 16-09-2007, 01:10 PM   #5 (permalink)
Dreamweaver
Gigacore's Avatar
+1 for shantanu's suggestion
Gigacore is offline
Old 17-09-2007, 06:05 PM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
also check RAM modules .... r they suitable frq 4 ur mb .......
... W H O T ...
ax3 is offline
The computer virus turns 25 this year zyberboy Random News 14 30-07-2007 01:12 PM
CPU Turns Off By itself Shikher_neo Software Q&A 5 16-06-2007 12:36 PM
Whenever i turn my UPS on, the whole computer turns on nnw077 Hardware Q&A 11 11-12-2005 08:07 PM
computer turns off suddenly abhishek_sharma QnA (read only) 6 12-07-2005 11:37 AM
