Old 15-09-2007, 02:41 PM   #1 (permalink)
Default hi abt lcd...
hi,
just brought a new LCD display - viewsonic vx1932wm, its cool, colors looks great, super bright! it rocks!
but there is one doubt i have:
do all lcd's display some kind of rings on faces while watching movies( i can see it only observed closely...)
from a little away it looks great!
so tell me is it another one of lcd's drawbacks..?
sai_cool is offline
Old 15-09-2007, 07:32 PM   #2 (permalink)
vinaych's Avatar
Default Re: hi abt lcd...
Hii Sai..
Even i have the same problem while watching videos.. Rings/Fringes appear in case of a bright object or bright light..
My problem: Problem with Viewsonic VX1932wm LCD
vinaych is offline
Old 15-09-2007, 09:54 PM   #3 (permalink)
Are you using it at the native resolution and using DVI cable?
My one year old 19" VS doesn't have any such problem.
V.Prem Kumar
janitha is offline
Old 15-09-2007, 10:28 PM   #4 (permalink)
Attitude matters
Ponmayilal's Avatar
@janitha, didn't you get your monitor replaced recently?
Ponmayilal is offline
Old 16-09-2007, 04:55 AM   #5 (permalink)
yes at native also same problem, and i am using dvi cable with geforce 6600
sai_cool is offline
Old 16-09-2007, 01:18 PM   #6 (permalink)
Yes, got replacement (second time) recently and works perfectly.
V.Prem Kumar
janitha is offline
Old 17-09-2007, 02:55 PM   #7 (permalink)
whom did u call to get replacement?>
sai_cool is offline
Old 17-09-2007, 06:46 PM   #8 (permalink)
Toll free number of VS. 1800 11 99 99.
Call, give details and the sl. number of the monitor and you will get the RMA number. The monitor will be checked/taken for service the next day or so.
V.Prem Kumar
janitha is offline
