Old 15-09-2007, 02:11 PM   #1 (permalink)
NP : Crysis
xbonez's Avatar
Default Buying AMD 939 pin Procy
fellow geeks, which AMD procy will fit in within my budget of rs. 4000 approx. It must be 939 pin.
Also how much should i expect for my 1.5 yr old AMD Athlon 64 3200+ ??
xbonez is offline
Old 15-09-2007, 02:23 PM   #2 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
Default Re: Buying AMD 939 pin Procy
that 939 series is closed now and prolly u wont get a new one.get some AMD X2 - 4400+.new one costs 4k
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 15-09-2007, 02:59 PM   #3 (permalink)
NP : Crysis
xbonez's Avatar
oh man!! thats bad. i can't even go for AM2 procy, coz i'll then have to change mobo too, which will then also most probably require me to change RAM.
xbonez is offline
Old 15-09-2007, 09:46 PM   #4 (permalink)
Most probably you will have to get it second hand. Try to get Opteron.
BTW I am also still with my Venice 3000.
V.Prem Kumar
janitha is offline
Old 15-09-2007, 11:36 PM   #5 (permalink)
slugger's Avatar
if u live in/close to Delhi Mumbai den u mite wan2 check out Nehru Place Lamington Road resp
some dealer may still have a 939 processor (of ocurse u will probably have to do a lot of searching, but @ least in these 2 places all the shops are in one location itself)
slugger is offline
Old 15-09-2007, 11:52 PM   #6 (permalink)
NP : Crysis
xbonez's Avatar
yeah, i live in Delhi so i'll check Nehru Place. do u think SMC Intl. will have them?? they keep all AMD products
xbonez is offline
Old 16-09-2007, 05:41 AM   #7 (permalink)
Gizmo Freak !
spitfire's Avatar
Buddy Dont commit an upgrade right now...It just might prove to be too costly for you !!! A64 3200+ still packs enough punch to do away with modern applications..rather wait 1 more year and then go for new AM2+ socket cpu with new mobo and ram !!
And BTW you can expect around 1k-1.2k for you cpu if you sell it right now !
spitfire is offline
Help in Buying the Procy Mobo combo! joelf15 Hardware Q&A 12 24-06-2007 11:37 PM
Buying PC..... damnthenet QnA (read only) 4 28-05-2007 07:42 PM
which mobo, procy? xbonez Hardware Q&A 6 06-05-2007 02:04 PM
Intel Responds to AMD's Quad FX System with 8 core procy iMav Technology News 5 09-01-2007 03:49 PM
