Old 12-09-2007, 03:57 PM   #1 (permalink)
abhinav_bipnesh's Avatar
Question Problem with DLink ADSL 2/2.0+ 2640-T
Hi!
I am using DLink 2640-T ASDL Modem for my Tata Indicom Broadband connection which support the wifi access. the problem with this modem i am facing it is that if i define any new rule to forward the port for my torrent application it loose out its setting when i switch off the modem & agin switch on . so how to make that it rember it setting even after power down.
I am using the DHCP configuration so that i am getting a dynamic ip each time but most of the tiume same ip is assign to my machine.
Help me out guys.............
abhinav_bipnesh is offline
Old 12-09-2007, 04:51 PM   #2 (permalink)
Pee into the Wind...
shady_inc's Avatar
Default Re: Problem with DLink ADSL 2/2.0+ 2640-T
Maybe this can help you
http://www.portforward.com/english/r...2640Tindex.htm
Life is as complicated as you say it is.
shady_inc is offline
Old 12-09-2007, 05:21 PM   #3 (permalink)
i have done the setting which is given in this page but my problem is that it forget whatever setting i do when i switch off & switch on the router again i.e. the power supply ......
Old 13-09-2007, 07:04 AM   #4 (permalink)
Laptoping
Sourabh's Avatar
Do you save the settings before restarting?
Sourabh is offline
Old 13-09-2007, 09:00 AM   #5 (permalink)
make settings change and then save them , so tht modem will remember the settings.
dabster is offline
Old 13-09-2007, 09:50 AM   #6 (permalink)
how to do that as after writing the rule i just click the apply button & thats it it remember that rule for that whole session. also sometime my ip change as some other machine take that ip so who to specfy my ips so that rule remain with my ips (as i have laptop so i have a wireless & lan card so two ip ).
Please help me out........
Thanks
Old 13-09-2007, 02:57 PM   #7 (permalink)
Laptoping
Sourabh's Avatar
Not familiar with the Dlink model you've got but it's obvious that you're not saving the settings for future sessions. You will have to find out where this option is (usually it's there along with the option to restart the router manually).
The 'Save All' option is what you need to find on the Dlink interface.
Sourabh is offline
Problem with OS/ADSL Modem/Net Connection??? go4saket Networking 8 26-08-2007 02:23 PM
help dlink adsl 2+ glb-502T configuration mtech84 PC Components / Configurations 1 28-09-2006 07:04 PM
ADSL getway problem Choto Cheeta Hardware Q&A 11 26-11-2005 01:42 AM
