Old 11-09-2007, 08:06 PM   #1 (permalink)
Post Urgent reply Needed
Firstly Thank and i appreciate the work you are doing. i have learned a lot from it.
This time i would like to place a query that is :
Recently i purchased a system
Intel Core 2 Duo 2.33 IE 6550 a number on the box
Intel OG D33FD Mother Board
I ball Work Horse Cabinet
Transcend Ram 1GB 667 FSB
Western Digital HDD SATA 250 GB
I don't Have a UPS
Now My Questions
1] How Good is the processor and the mother board ?
2] What about the cabinet as it has 400 Watt SMPS ?
3] Is 400Watt Sufficient or i have to go for higher?
4] Is Zebronic Fat Cat better than this cabinet ?
5] Which Higher SMPS and of which company i should purchase ?
5] Which UPS is good both with price and maintenance factor?
6]Which cabinet is good ?
7]Pls Tell me more about my processor and board?
Waiting for your reply?
Thank You
poni is offline
Old 11-09-2007, 10:48 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Urgent reply Needed
1. proccy is good, mobo is ok
2. Cabinet is good enuf..
3. 400w is enuf..
4. yup a zebby is definitely better
5. No need
5. No idea
6./7. Google rox
Pathik is offline
Old 11-09-2007, 11:06 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
1. Processor is good..
for Motherboad either choose Intel 975 series OR ASUS PSB(8k)
2. No idea
3. 400 watt is sifficient..but i will recommend you 600watt SMPS
4. No idea
5. VIP 600 watt
6. As told by pathiks..google..or contact choto cheeta
ravi_9793 is offline
Old 12-09-2007, 07:16 PM   #4 (permalink)
Maximum Fame
quadroplex780's Avatar
APC is the best ups manufacturer even the 650VA ups is good enough for a monster rig i run my P5N32E-Sli on it with an 8800 GTS 640MB and core 2 duo e6600 with no problems.
quadroplex780 is offline
Old 14-09-2007, 09:32 PM   #5 (permalink)
napster007's Avatar
u'll need a high end smps if ur planning to fit the almighty 8800 series
napster007 is offline
Old 15-09-2007, 01:53 AM   #6 (permalink)
Nav11aug's Avatar
u shudve seriously gone in for more RAM dude
http://www.last.fm/user/NOLFxceptMe/
http://naveendageek.blogspot.com
Back after a long time. And well, EndSems screwed up as usual :)
Nav11aug is offline
Urgent reply Needed poni Hardware Q&A 5 15-07-2007 11:58 PM
Urgent DVD Writer Query: Reply in 2 Hrs raksrules QnA (read only) 1 05-11-2006 11:10 AM
VERY VERY URGENT.....PARTITION ERROR.PLZ REPLY NOW.. medigit QnA (read only) 3 15-03-2006 04:14 PM
Reply URGENT Please - MoBo For AMD 3000 adityainalps Hardware Q&A 8 03-03-2006 07:19 PM
HELLLLLLP VERY URGENT!!!!! PLEASE REPLY SOON!!! KKK Hardware Q&A 5 16-02-2006 08:58 PM
