i am a new forum member...
just wanted to ask whether i should connect 256mb with 1gb
(in asynchronous mode) whether it will be a bottleneck?...
or i should go for 1gb in a single slot (will it give better performance?)
i already have 256mb which i do not want to dump...
and shell out min as possible!
its always better to use the 2 exactly sam ram modules, but u can still try and yes i think they shud be of the same frequency as well
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
