Old 11-09-2007, 12:01 PM   #1 (permalink)
Red face having problem with RAM
i have mercury 845gl board with 128sd ram installed on it
and now i have added 1gb ddr400mhz
ram is supported by my board but on xp setup this gives fetal error
and i also added 160 gb hdd & dvd writer but they work perfectly with 128 sd ram
give me proper solution
dushyant6883 is offline
Old 11-09-2007, 12:42 PM   #2 (permalink)
Default Re: having problem with RAM
You mean you're using both the sdram and the ddr together?If so,remove the sdram and use only ddr.
sashijoseph is offline
Old 11-09-2007, 12:51 PM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
Right you need to remove the SD RAM to make the DDR work..
Even still there should be a LONG set of Jumpers one would need to reset to make the DDR work...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 11-09-2007, 02:03 PM   #4 (permalink)
i have already remove 128sd ram
if there is another setting on board plz tell me
Last edited by dushyant6883; 11-09-2007 at 02:04 PM. Reason: Automerged Doublepost
Old 11-09-2007, 02:04 PM   #5 (permalink)
Rebooting
Jumpers, brother, a long set or Jumpers u need to reset before u can use the DDR RAMs !!!
rebooting
ChotoCheeta.com
Old 11-09-2007, 02:51 PM   #6 (permalink)
Question Re: having problem with RAM
plzzzzzzzzz tell me in detail
i dont know abt which jumper setting you tell
Old 11-09-2007, 06:48 PM   #7 (permalink)
Hey read the motherboard manual.It should be elaborated there.Should be a set of some 8-10 jumpers just next to the ram slots.
Dig out the manual and do what's written there.
Old 11-09-2007, 06:51 PM   #8 (permalink)
Rebooting
If possible please post the exact model number of the board... or else as said avobe my post, that refer to the manual of the board
rebooting
ChotoCheeta.com
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
