Old 10-09-2007, 04:41 PM   #1 (permalink)
Kalyan's Avatar
Default Problem with keyboard
I got a frontech keyboard.
http://www.frontechonline.com/keyboa...&&jilcode=8061
This has got a USB interface. The website mentions a "USB & PS 2 (UP COMBO) interface" but I didnt get it. I have installed the driver and utility that came with the driver cd. When my windows starts up, the utility works fine. when I press any special button on the kbd, it works fine with the display on monitor. But after some time or when I disconnect any pendrive or so, it stops working and I have to run the utility from sys32 folder. Do I have a way to make the kbd work fine? I also have vista installed and the kbd works fine in vista even without any drivers installed. but in xp, without drivers, the kbd wont respond to the extra keys. the kbd also doesnt show up in the 'safely remove hardware' list. How to keep it enabled in xp?
Please help. I tried getting a USB to PS2 connector. but I was shown a PS2 to USB connector at the shop for nearly Rs.80. Would having a USB-PS2 connector solve my prob?
Kalyan is offline
Old 10-09-2007, 06:32 PM   #2 (permalink)
assasin's Avatar
Default Re: Problem with keyboard
even i had that same kbd.it usewd to work fine in Win XP SP2 without any drivers.all multimedia keys worked flawlessly.also any device other than USB Mass Storage Devices (i.e pen drive,card reader,hdd etc) wont show up in the 'safely remove hardware list'.even i received the kbd w/o the "USB & PS2 (UP COMBO)".
if u want u can buy a connector.all it will do is free up a usb port.
assasin is offline
Keyboard Problem ChaiTan3 Open Source 19 03-07-2007 08:21 PM
Keyboard Problem Soumyajit Hardware Q&A 1 05-05-2007 08:14 PM
keyboard problem? bhoolkumehul Hardware Q&A 1 27-11-2006 05:43 PM
Keyboard Problem.. vandit Hardware Q&A 13 19-09-2006 02:46 PM
Keyboard Problem bendre123 QnA (read only) 1 30-06-2005 11:55 AM
