Old 09-09-2007, 07:53 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default Wifi Router with Cable & DSL Internet Gateway functionality
Hi All,
Has been long since I posted in this forum.
Ok my query is, I need a WiFi Broadband Gateway Router which should be compatible with both Cable & DSL technologies.
Currently I am using Hathway Cable Service where I use Motorala Surfboard SB5100. I connect the Cable modem to PC through ethernet card and assign static IP to the ethernet card.
But in future I am thinking of going to DSL connection from Airtel or BSNL.
So I want the WiFi router to be compatible with both the technologies.
I tried a search here but couldn't find a solution.
So request you all to please give me a solution.
Regards,
Kannan
Kannan.
Binary Bits
http://www.binarybits.net
Kannan is offline
Old 09-09-2007, 10:08 PM   #2 (permalink)
Default Re: Wifi Router with Cable & DSL Internet Gateway functionality
i don't think there is one available...actually wifi router with dsl modem are available... they have 2-4 lan ports as well...so u can plug ur existing cable modem to one of these ports.. this way ur pc can connect both thru cable as well as dsl..
Ankit is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/67765-wifi-router-cable-dsl-internet-gateway-functionality.html
Thread Good WIFI N series router | Digit Forum | BoardReader This thread Refback 12-12-2010 12:29 AM
How To Share PC's Internet via BT and Wifi on a SE P990i quad master Hardware Q&A 1 22-07-2007 09:30 AM
Newbie needs advice on sharing Sify B'band using WiFi router Monster_AMD Networking 3 09-02-2006 05:33 PM
how to get cable tv in a cable internet connection bishnu_rath Internet & WWW 13 12-03-2005 12:52 PM
