Old 08-09-2007, 11:08 PM   #1 (permalink)
tinku dhar's Avatar
Default DIGIT Fellas i need ya help (MY DVD/CD WRITER not workin)
Well ... ,
guys i have seens thie prob frm quite a while now ... my SONY DVD/CD WRiter does'nt work after few days .... it reads DVD / CD all typo but it does'nt Write/BURN any ....
dunno wats the prob but frm today its showin BAD sign now ... since it works after formatin soooo i formated my PC and it can be BURNED any CD/DVD now but just i restarted my PC and its not workin again
again formated and same prob ... in windows writtin it sayins plz insert ya dics
pplz plz help me im tensed
thnx in advance
tinku dhar is offline
Old 08-09-2007, 11:38 PM   #2 (permalink)
Rubik's Uncle!!
Charan's Avatar
Default Re: DIGIT Fellas i need ya help (MY DVD/CD WRITER not workin)
If its under warranty then get it checked/replaced. Dono about others but for me Any optical drive is use and throw. get the max till the warranty exists. later throw away and buy a new one. I have trashed 4-5 drives till now.
Charan is online now
Old 09-09-2007, 08:37 AM   #3 (permalink)
tinku dhar's Avatar
Unhappy Re: DIGIT Fellas i need ya help (MY DVD/CD WRITER not workin)
well nah my old CD WRITER had same prob ..... i mean when i re- format the PC it writes properly and lata not and bought this DVD/CD writer and i c the Same prob its kinda Windows Prob dunno where is the place in Windows for this stuffs to FIX ...
Old 09-09-2007, 08:52 AM   #4 (permalink)
Try a different version or different software for burning.Also run a thorough scan of your hdd with a good and updated antivirus.
sashijoseph is offline
Old 09-09-2007, 08:56 AM   #5 (permalink)
tinku dhar's Avatar
well ... ,
dunno watz the matter .... it 1st time shows DVD/CD DRIve and after a single restart it just shows CD h :/
icon changed toooo
u mean the drivers versions etc etc ?
DVD writer wont read DIGIT dvds assasin Hardware Q&A 10 12-10-2007 09:39 AM
Fellas please tellme which one? genx069 QnA (read only) 5 05-08-2007 04:17 PM
dvd writer not workin properly. it gives blank dvd's after burning. tango_cash Hardware Q&A 7 07-06-2007 03:06 PM
cd rom not workin.. anil_861 Hardware Q&A 15 08-09-2006 01:43 AM
Using msn thru Trillian ,not workin Charley QnA (read only) 13 08-10-2005 07:27 PM
