Old 08-09-2007, 10:32 PM   #1 (permalink)
swap_too_fast's Avatar
Unhappy Monitor colors gone
the colors of my pc's monitor at right bottom are changed. Can you tell me what is the cause of it and solution?
I changed my pcs location in home, then at right side of monitor i placed spike guard, 1 big 12 volts dc variable adaptor pluged in spike guard and telephone and mobile is also there, but i think mobile dont cause any problem to monitor colors.
plz help me and tell solution for this...
There is no second chance.....!!!!
swap_too_fast is offline
Old 08-09-2007, 10:37 PM   #2 (permalink)
Pee into the Wind...
shady_inc's Avatar
Default Re: Monitor colors gone
Tried degaussing the monitor??
Life is as complicated as you say it is.
shady_inc is offline
Old 08-09-2007, 10:49 PM   #3 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
If your are using CRT monitor and placed any magnetic item in the right side of your monitor it may cause problem. remove such item approximately 1 feet distance. I think problem will be sloved.
________________________________________________
I like signature after 10 P.M.
skghosh44 is offline
Old 08-09-2007, 10:54 PM   #4 (permalink)
Rubik's Uncle!!
Charan's Avatar
This always occurs when you change the monitor position. This is fixed using degausing and it hardly takes 5 seconds to do it.
Please give monitor model number. Also check manual on how to degause yout monitor.
Charan is online now
Old 09-09-2007, 10:27 PM   #5 (permalink)
MY monitor is LG studioworks 563N, well is digausing can be done at home without any other person, if yes then tell me procedure.
Old 09-09-2007, 11:08 PM   #6 (permalink)
Rubik's Uncle!!
Charan's Avatar
^^ Check this
Old 10-09-2007, 08:21 PM   #7 (permalink)
Smile Re: Monitor colors gone
I asked my teacher about htis problem and they tell me like u to deguase it and also show procedure, Thanks to all of you and also my teacher for solving this problem.
iPod Shuffle to be available in various colors gdatuk Technology News 6 31-01-2007 06:20 PM
colors in c language... tweety_bird_bunny Programming 3 27-07-2006 11:23 AM
Nokia 6610 colors ! ! ! ax3 Mobiles and Tablets 16 05-07-2006 10:26 AM
bash colors and icewm themes ra_rav Open Source 6 02-03-2006 06:33 PM
