Old 08-09-2007, 05:56 PM   #1 (permalink)
Devrathnd
Posts: n/a
Default Lite-on Dvdrw Lh-20a1p
I am not able to read or write to DVD+RW from LITE-ON DVDRW LH-20A1P.
i run winxp sp2. i upgraded my firmware to LON
Old 10-09-2007, 04:23 PM   #2 (permalink)
Devrathnd
Posts: n/a
Question Re: Lite-on Dvdrw Lh-20a1p
why my dear friends dont want to help me
Old 10-09-2007, 05:04 PM   #3 (permalink)
ajayritik's Avatar
Default Re: Lite-on Dvdrw Lh-20a1p
Dude I'm facing similiar problem too! Dont know what the cause for this is?
ajayritik is offline
Old 10-09-2007, 09:25 PM   #4 (permalink)
ok . i have same drive ... firmware is "klon" ... now tell me what is the brand of dvd +rw .. is it moser baer ..? if ur firmware is not this .. then update it to this one first and then try
yogi_7272 is offline
Old 11-09-2007, 06:28 AM   #5 (permalink)
Devrathnd
Posts: n/a
It is Sony Accucore DVD+RW
Old 11-09-2007, 10:44 AM   #6 (permalink)
ajayritik's Avatar
DVD-RW is Sony. I have no idea about what firmware is and how to update it.
Old 11-09-2007, 01:17 PM   #7 (permalink)
I have the same writer, me facing problem with sony accucore dvd+r, the media code is d21. I wasted 2 dvd's yesterday, it writes and suddenly gives the error burn failed. Today i updated to latest firmware KLON, will try again today and see if it burns properly or not.
casual_gamer is online now
Old 11-09-2007, 01:58 PM   #8 (permalink)
ajayritik's Avatar
Hi Casual gamer and Yogi can you tell me how to update the firmware? I'm also facing the same problem with Liteon.
Old 11-09-2007, 02:55 PM   #9 (permalink)
here's the link http://www.liteonit.com/global/index...per&Itemid=154
in the category select optical storage and select ur dvd-writer model number(LH-20A1P in my case). download and run it. it will take 2 minutes to update writer to latest the firmware.
Old 11-09-2007, 05:37 PM   #10 (permalink)
ajayritik's Avatar
In one of similiar threads on Updating firmware for Liteon I found that we need to make some changes. Something like DMA.. Any idea about that?
Old 11-09-2007, 07:16 PM   #11 (permalink)
I am not sure if enabling DMA is a must for firmware update..but mine is enabled. In DMA mode, the speed is almost 4 times that of PIO mode. for great speeds and burns its good to enable it.
Old 11-09-2007, 07:32 PM   #12 (permalink)
ajayritik's Avatar
Can you tell me how to check whether I'm in DMA mode or PIO mode? So according to you DMA mode is better thatn PIO? Please let me know how to change if its not in DMA mode
Old 11-09-2007, 07:56 PM   #13 (permalink)
TheSaint
NucleusKore's Avatar
I am surprised, I have the same drive but no issues so far
:-S What's your firmware number
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 11-09-2007, 08:30 PM   #14 (permalink)
check out this nice tutorial with images, it will be much easier for u than me explaining http://www.onthegosoft.com/dma_setting_nt.htm
If your motherboard is Intel and if u have installed Intel Application Accelerator software, then DMA will be enabled by default.
Old 20-09-2007, 07:21 PM   #15 (permalink)
ajayritik's Avatar
After updating with latest firmware for my Liteon DVD Writer I still face the same problem. My Writer doesnt recognize a DVD RW disc. When I tried to burn it in my friend's computer I'm able to burn it.
Old 20-09-2007, 08:42 PM   #16 (permalink)
which brand of dvd rw disc ?
Old 21-09-2007, 11:18 AM   #17 (permalink)
ajayritik's Avatar
Sony DVD-RW. Its working on my friend's computer! He has a HP DVD Writer!
Old 21-09-2007, 04:47 PM   #18 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
hey @Devrathnd ... if its SONY then y did ya mention liteon drive ?
update drivers .... try @ ur frds place ...... take 2 service guys ...
... W H O T ...
ax3 is offline
Problem with Liteon & Samsung 20X DVDRW Kalyan Hardware Q&A 5 06-10-2007 11:32 PM
Lite On LH-20A1P DVD-Writer problem aritrap Hardware Q&A 20 20-09-2007 07:20 PM
HELP!!! Spilt Tea On DVDRW Tray :( pannaguma Hardware Q&A 4 26-07-2007 10:15 PM
Some serious prob with Liteon DVDRW gaurav4gurls Hardware Q&A 1 09-05-2007 02:52 PM
