Old 08-09-2007, 06:31 AM   #1 (permalink)
back to future
prasad's Avatar
Question ony beeps while boot up..help needed.
My PC crashed and when it boots up, ends in some beep sounds. Three beep sounds with around 1 sec lenght and same delay in between, then a few secs delay and repeats. As my friend said I replaced the RAM but problem persists. Any advice?
It was ASUS and Sempron 2200+ working fine with 128 MB RAM.When I turn my PC on now, I can see the processor fan is rotating along wi
"The only one thing everyone love to loose is virginity"
prasad is offline
Old 08-09-2007, 09:03 AM   #2 (permalink)
Distinguished Member
anandk's Avatar
Default Re: ony beeps while boot up..help needed.
Three Long Beeps - Keyboard Error
http://www.chicopee.mec.edu/computer...beep_codes.htm
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 08-09-2007, 09:27 AM   #3 (permalink)
back to future
prasad's Avatar
1 sec beep is short, no?
prasad is offline
Old 08-09-2007, 11:47 AM   #4 (permalink)
slugger's Avatar
wat BIOS do u have and model number of ur ASUS mobo?
Beep codes wary between BIOS and motherboard mfg?
keyboard failures r usually displayed on the monitor
if keyboard replacement doesnot solve ur problem den post those two details
i suggest dat u connect ur friend's keyboard 2 c if it is wirkin on ur comp or taske urs to ur friend's place
slugger is offline
Old 08-09-2007, 12:20 PM   #5 (permalink)
back to future
prasad's Avatar
Smile Re: ony beeps while boot up..help needed.
Here my computer stops before displying anything on the monitor.let me check the KB n i'll get back here. Thanks.
prasad is offline
Old 08-09-2007, 01:40 PM   #6 (permalink)
slugger's Avatar
u will find d necessary info in the manual provided the mobo
slugger is offline
Explanation of boot.ini needed..!! Plzz Help damritraj Software Q&A 6 01-07-2007 09:58 PM
Suspected BOOT virus, help needed urgently??? Andyiz Software Q&A 2 15-08-2006 06:33 PM
my pc only beeps; does not boot......heeeelp Omsck Hardware Q&A 9 28-07-2006 11:38 AM
Boot options needed ! rajkumar_personal Software Q&A 1 20-02-2006 05:13 PM
Computer dosent boot-Cont. short Beeps-Pl. help rahul_becks23 Software Q&A 2 06-01-2005 11:51 AM
