Old 06-09-2007, 11:15 PM   #1 (permalink)
Default PLZZZ suggest !!!
Hey Friends,
I have seen this problem quite oftenly with few systems...
plzzzz suggest... Reasons & Solutions to this error....
image is attached...
thanks n be quick plzzzzzzz...
Sophocles.
sophocles1997 is offline
Old 07-09-2007, 11:39 AM   #2 (permalink)
slugger's Avatar
Default Re: PLZZZ suggest !!!
first STOP GIVING THREAD TITLES LIKE PLZZZ SUGGEST or sumthin like that
ur title must give d members a fair idea of what problem the member is facin even b4 he/she opens the thread
when is it that u face this problem? immediately after booting or after using the comp for sum time
have u recently installed any new hardware on the comp dat is facin this problem? if yes, then remove it and then c if d problem dissappears
if the problm contonues then revert back to the last known good configuration
check if ur comp's hw config can run XP
4 better solution post the error codes dat appears in
STOP: message
slugger is offline
Old 07-09-2007, 01:49 PM   #3 (permalink)
Default Re: A problem has been detected....
dear slugger,
thank you for your reply....okay i'll keep that in mind...
i receive this error immediately after booting.
thanks,
sophocles.
---------------error----------------------
A problem has been detected and Windows has been shut down to prevent damage to your Computer.
If this is the first time you've seen this Stop error screen, restart your computer. If this screen appears again, follow thease steps:
Check for viruses on your computer. Remove any newly installed hard drives or hard drive controllers. Check your hard drive to make sure it is properly configured and terminated. Run chkdisk/f to check for hard drive corruption, and then restart your computer.
Technical information: STOP: 0x0000007B
Old 07-09-2007, 01:59 PM   #4 (permalink)
slugger's Avatar
How to troubleshoot "Stop 0x0000007B" errors in Windows XP
slugger is offline
Old 07-09-2007, 08:40 PM   #5 (permalink)
moshel's Avatar
ok first cud u pls provide us with ur comp specs.
moreover, tell us what major hardware/software installation/removals u did before u started getting that screen.
moshel is offline
Old 07-09-2007, 08:51 PM   #6 (permalink)
"The Gentleman"
vish786's Avatar
first do a system restore, and pressing f8 and choosing Last best known configuration, if this does not work then boot in safe mode, if u can boot into safe mode easily than like others said remove softwares or drivers which u recently installed.
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 07-09-2007, 09:53 PM   #7 (permalink)
heyyyyyy
i must say thanks to all of you....
problem is solved due to your help.
thanks
sophocles.
Old 07-09-2007, 10:31 PM   #8 (permalink)
TechTin.com
ravi_9793's Avatar
Originally Posted by sophocles1997
heyyyyyy
thanks
sophocles.
can you tell me..how the problem was solved...so, that we may also learn from this.
ravi_9793 is offline
PLZZZ Suggest a game!! hpindia Gamerz 2 14-08-2007 11:33 PM
what to doo plzzz help hackers2005.3721 Mobiles and Tablets 3 31-05-2007 07:24 PM
Help me out PLZZZ.... anweshkumar Hardware Q&A 11 08-04-2007 01:00 PM
plzzz suggest me the best cam phone below 10k pvr_harish Buying Advice 4 26-07-2005 12:18 PM
Plzzz Help Me.... eshansinharay QnA (read only) 2 25-09-2004 03:25 PM
