Old 06-09-2007, 06:49 PM   #1 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
Default High CPU temperatures!!
I posted the same problem in QnA section but didn't get enough replies so I am posting here again.I hope I will get the help I need here.
I have a core two duo processor E6300@1.86GHz.I just downloaded speed fan and it shows my cpu temp. to be:
Cpu: 51c
internal temp.: 39c
remote temp: 45c
hd0: 40c
core0: 54c
core1: 52c
I don't know much about the temperatures but there is a burning sign on cpu,core0,and core1 temperatures which has scared me.
Is the temp. normal or I need to do something?
I think the temp. musta been much higher in past months as the climate is much cooler now.
EDIT:I checked with my friend who has the same PC as me and he found out the temp. to be much cooler about 36c:cpu and around 40c:cores.This is scary.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 06-09-2007, 06:52 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: High CPU temperatures!!
While 51 isn't something to lose hair upon, it certainly is hotter than it should be. How good is your cooling in the cabinet?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 06-09-2007, 07:20 PM   #3 (permalink)
M$™ Certified Spammer
entrana's Avatar
maintain a good airflow or put a fan near it if that would help, also u cud try being in a airconditioned environment and if that doesent help, wel u cant just open the laptop so try going to techies
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Old 06-09-2007, 07:41 PM   #4 (permalink)
Pee into the Wind...
shady_inc's Avatar
My celeron processor runs at 55-56 degrees. !
Life is as complicated as you say it is.
shady_inc is offline
Old 06-09-2007, 09:11 PM   #5 (permalink)
There is a coolermaster(at least the sticker claims it to be a coolermaster) fan(small one I guess) just above the heatsink and for the past two days I have opened my cabinet to allow full air flow but still no relief.
BTW My company made PC is still under warranty can I claim a replacement(of processor or heatsink) or atleast a reapir?
Old 06-09-2007, 09:15 PM   #6 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Please download coretemp i don't think speed fan is reliable.Coretemp is made for core 2 duo.It'll show the right temperature.
Harvik780 is offline
Old 06-09-2007, 09:21 PM   #7 (permalink)
Commander in Chief
My Prescott runs at 70 degrees, no sweat.
Harsh J
www.harshj.com
Old 06-09-2007, 09:47 PM   #8 (permalink)
I have core temp.(version 0.95.4) too harvik and it shows the same temperatures i.e. core0:53 and core1:51.It also shows Tjunction:85c although I don't know what is that.
And yes thanks for replying.
Old 07-09-2007, 02:58 AM   #9 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Tjunction is maximum temperature to shutdown and for core 2 duo its 85C
Old 07-09-2007, 08:11 AM   #10 (permalink)
Any suggestions for the heating problem dude?
Old 07-09-2007, 10:36 AM   #11 (permalink)
I have a long thread of the same issue & my vendor told me just chill.............................nothing to worry about I did many thing but could not get the cpu temp at 35-37 degrees.
Here is the link to that post CPU remains overheated...........tried many options!!!!!.
Mine is the same processor, I changed 2 cabinets, 2 PSU refitted the processor but it still runs at 46 degree & my vendor said u burn it as much as u can, he will get it replaced under 3 year warranty.
He said so bcoz Intel core 2 dou have built in shield to shut down the comp at 85 degree, so u actually cant burn the processor. Running it hot actually does not indicate any problem as such except that you always keep in mind that ur friends comp is running cooler.
Mine is running perfectly, I over clock at times & the temp goes upto 60 degree even then it runs fine I have no problem, I was thinking to get gemini CPU cooler but still have not bought it. Its known to bring down temp by 7-10 derees.
If u visit any international forum & report that urs is running at 51 & ur friend at 35, they would say even 35 is higher, most of them would aim at 25-28 bcoz they use aftermarket heatsink fans.
Just chill u wont burn ur processor, though in my long post on the same issue I concluded that the difference is due to heatsink is not flat & it needs "lapping" thats the only thing I did not try.................that option is still open, but I am running fine though its hot as posted in screenshot below. Thisi was taken in summer time now it runs cooler at around 46-49, but the point I am making is that at higher temp too it was working fine.
ranjan2001 is offline
Old 07-09-2007, 11:38 AM   #12 (permalink)
Rebooting
Choto Cheeta's Avatar
@The_Devil_Himself
Cpu Temperatures
Why double Posting ??? few Solution is given there.... !!!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 07-09-2007, 06:35 PM   #13 (permalink)
Sorry choto cheeta for double posting but I didn't get enough responses in that section.
Ok my final question What can I do to lower my PC'c high temp.?I am currently on stock cooling.
Old 07-09-2007, 07:01 PM   #14 (permalink)
first of all, clean ur cabinet .. remove all the dust . then try to clean ur stock heatsink ..and apply some arctic silver mx 2 thermal paste on ur cpu ..
also put some exhaust fans on the back .. put as many as ur case permits .. normally max 2 80mm or 1 120 mm fan ... also try to put one 80 mm intake fan at the front bottom side of ur cabinet if it has place for one ..
try this .. if it does not help and u can spend upto 3 k then, get thermalright ultra 120 extreme cpu cooler .. will solve ur all problems..
yogi_7272 is offline
Old 07-09-2007, 09:33 PM   #15 (permalink)
I have all the fans installed 3 in total.Guys I was also thinking about buying arctic silver 5 but I have no Idea how to remove my stock heatsink and then apply it.I am scared of doing it.How tough is it guys?Actually the problem is if I happen to f*ck my PC then I ain't gonna get a new one soon.
Old 10-09-2007, 09:04 PM   #16 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
Core0: 47-54C @ at idle
..in my laptop
jin files ka koi server nahi hota unka bittorrent hota hai
chesss is offline
Old 10-09-2007, 09:08 PM   #17 (permalink)
too high dude.means it will cross 65c easily on high loads(like me)
Old 10-09-2007, 09:54 PM   #18 (permalink)
damn busy...
utsav's Avatar
my OCed P4 3.45GHz HTprescott never crosses 62degrees at full load without A/C and also with stock cooling
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 10-09-2007, 10:01 PM   #19 (permalink)
^^thats good man p4 is suppoed to produce more heat owing to it's 90nm core compared to 60nm core of core2duos.
But suggest something guys which will help me solve my problem.I don't want a fried e6300.
Old 10-09-2007, 10:08 PM   #20 (permalink)
damn busy...
utsav's Avatar
yesterday i assembled a C2D E4400 PC for my frnd .the cpu fan got entangled in the wires and the proccy temp shot up to 96 degrees .i was out o breath for a moment but rectified the prolbm soon.
most important thing for cpu cooling .get a big cabby with lots of air vents and place more fans for exhaust in d cabby.
www.techjunkiez.com
utsav is offline
Old 10-09-2007, 10:12 PM   #21 (permalink)
I keep my cabby open so really a lot of air vents and air flow.I have 2 exhaust fans still this overheating problem is gonna kill me.I hate it even as I know the upto 60c there is no problem.I WANT IT LOWER.
BTW utsav how did you manage 96c?It is supposed to auto shut down at 85c(tjunction temp.)
Old 10-09-2007, 11:20 PM   #22 (permalink)
hahhahah...................................keeping it open is the 1st thing which will work against the temp, when open the rear exhaust wont suck the hot air out.
If u have 2 rear fans out make sure u have 2 front intake fans to maintain the proper airflow. keeping it open is no real solution for the processor heat, either u have a real bad heat sink & that will require lapping it, or ur heatsink fan is not seated properly.
Old 11-09-2007, 07:12 AM   #23 (permalink)
^^Yea I guess so but how do I 'lap' it?I haven't ever touched the heatsink so what do you think is reinstalling the heatsink tough?
Old 11-09-2007, 02:58 PM   #24 (permalink)
Lapping is a longer process & would require some reading on the web, 1st try getting a artic silver5 & reinstall the processor & heat sink, see if that solves the problem.
Cpu Temperatures The_Devil_Himself CPU / Motherboards 4 06-09-2007 12:26 AM
Tell the normal temperatures codename_romeo Hardware Q&A 3 15-11-2006 11:14 AM
High temperatures with AMD 64 cyrux Hardware Q&A 12 31-03-2006 06:24 AM
CPU temperatures pratheesh_prakash CPU / Motherboards 9 13-01-2006 09:40 PM
CPU Temperatures teknoPhobia CPU / Motherboards 38 19-10-2005 12:48 AM
