Old 05-09-2007, 07:59 PM   #1 (permalink)
Pee into the Wind...
shady_inc's Avatar
Default My motherboard is fried!!
Recently I got a new mobo for my GPU.But soon after making the connections,as soon as I switched the power supply on,the lot of smoke came out of my cabinet with some burning smell.I switched off the supplies immediately.Looking around for what might be damaged,I found only a small part near the 20-pin connector was fried.Rest all parts working fine with old mobo.It isn't a PSU fault either.What went wrong here??
Life is as complicated as you say it is.
shady_inc is offline
Old 05-09-2007, 08:18 PM   #2 (permalink)
slash_89
Posts: n/a
Default Re: My motherboard is fried!!
was it an IC that got burnt.
Old 05-09-2007, 08:35 PM   #3 (permalink)
shady_inc's Avatar
I don't really know the what's-called-what of PC hardware.It was just a small area close to 20-pin plug that was burnt,if that's any help.
Old 05-09-2007, 08:47 PM   #4 (permalink)
M$™ Certified Spammer
entrana's Avatar
cud u post a pic so that we cud help you better
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Old 06-09-2007, 05:29 AM   #5 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
@shady_inc are u experienced in installing pc components.
Sure u didn't forget to add the mounting screws in the cabinet for the motherboard??
Harvik780 is offline
which motherboard!! the_devil Hardware Q&A 1 02-12-2006 05:08 PM
my mobo is fried! goobimama CPU / Motherboards 7 15-06-2005 11:25 PM
I fried my hard disk... Wanna Taste? theKonqueror QnA (read only) 2 25-12-2004 12:16 AM
