Old 05-09-2007, 05:47 PM   #1 (permalink)
DD3030's Avatar
Arrow Best Webcam under 1.5K!!!
Hi all
I want your suggestions on a good webcam under 1.5K. Fixability on to of LCD and built-in-mic are plus but not a must. Purpose is google-talk.
Since the purpose is chat only, you can also suggest any good ones at low range like below 800/- also.
Also, let me know if webcams work fine with google-talk.
Cheers,
DD3030 is offline
Old 05-09-2007, 05:51 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Best Webcam under 1.5K!!!
I find Microsoft and Logitech cams a good, as with other brands I have faced a tons of Driver issue...
see you may buy a higher resolution cam but the problme is its hard to video chat with higher resolution cam in India.. so try to go with Logitech or Microsoft one and try to get lower resolution cams...
just stay away from the Local Frontech / Enter / Techcom type brands
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 05-09-2007, 05:52 PM   #3 (permalink)
You gave been GXified
gxsaurav's Avatar
Quantam has some for Rs 500, so does frontech.
If u can find in your area, look for Microsoft Lifecam VX-1000 & NX-6000
about.me/gxsaurav
gxsaurav is offline
Old 05-09-2007, 05:54 PM   #4 (permalink)
M$™ Certified Spammer
entrana's Avatar
i have creative webcam vista costing 1.5k its pretty decent with good quality u can try that if u want, plus its from creative, really good
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Old 05-09-2007, 08:26 PM   #5 (permalink)
Still Shining!
Lucky_star's Avatar
I had seen a 5 MP webcam from Enter recently. Is it really 5 MP? They offer many things with it, mini stand, night LEDs etc. And surprisingly it was available for Rs. 1500/-
@Choto, what do you say? Is it real?
I have a quantum .5 MP camera. Bought for 1500 in 2005. And its working perfect till now.
Nokia N86 8MP
Lucky_star is offline
Old 05-09-2007, 08:35 PM   #6 (permalink)
entrana's Avatar
i dont think we shud trust entry and ,well ,unknown brands last thing you wanna know its a local chinese brand
entrana is offline
Old 05-09-2007, 09:58 PM   #7 (permalink)
Pee into the Wind...
shady_inc's Avatar
Logitech 1300 wc.Though it's drivers don't support Vista.This cam got gold in this month's Digit in webcams ranging from 800 to 1700 (costs rs 1100)
Life is as complicated as you say it is.
shady_inc is offline
Old 07-09-2007, 05:49 PM   #8 (permalink)
DD3030's Avatar
Arrow Re: Best Webcam under 1.5K!!!
Many thanks for your replies
It seems in case of webcam, it is better to avoid sub 800/- models/lesser brands. Based on your inputs, I have decided to stick with Microsoft or Logitech. I will gather some more info on (before picking one of them):
MS VX-1000
MS NX-6000
LT QC Messenger
LT 1300
LT QC Vista
LT QC Family
LT QC Chat
Cheers,
I checked in creative too... when did you buy that? It seems latest prices are :
Creative Web Cam Vista 700/-
Creative Live! Cam Vista 1050/-
So cheeta what do you feel about creative webcams?
Therefore, enjoy as much as you can.....
DD3030 is offline
Old 07-09-2007, 06:09 PM   #9 (permalink)
Rebooting
yeah sure... good brand... My concern is only with Driver for the product for different OS !!!
Only just make sure the model you are buying is supported at their Driver page and drivers are available for Different OSes !!
rebooting
ChotoCheeta.com
webcam?? Manshahia Hardware Q&A 5 11-08-2007 06:42 PM
which webcam to buy? ssk_the_gr8 Hardware Q&A 14 21-12-2006 04:18 PM
Which Webcam is the BEST ? c()rrupt QnA (read only) 7 25-10-2005 11:41 PM
No WebCam !!! vishal QnA (read only) 7 25-10-2004 04:23 PM
