Old 05-09-2007, 04:55 PM   #1 (permalink)
slash_89
Posts: n/a
Exclamation Wrong processor for the mobo.
Hi guys,
my friend purchased a Core2Duo E4400,
he has an intel D945PAW mobo, its socket type is LGA775,
now my question is will this mobo(Intel D945PAW) be compatible and support the core2duo E4400?
and what kind of fan should be baught bcos the box packed fan does'nt fit in the slots,
plz have a look at the mobo and tellme, its pretty urgent.
Old 05-09-2007, 05:05 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Wrong processor for the mobo.
This board is not compatible with Core 2 Duo Processors... http://www.intel.com/design/motherbd..._available.htm
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 05-09-2007, 05:12 PM   #3 (permalink)
slash_89
Posts: n/a
But the board's socket type is LGA775 and so is the C2D socket type,
and plz checkout the attachment and tell me which cpu fan i'll have to buy to fit the slots.
Old 05-09-2007, 05:21 PM   #4 (permalink)
Rebooting
I did see it... LGA775 heat sink would fit is i soppose as the picture looks odd only may be because the Socket is titled a little so one may feel that LGA775 sotck HSF wont fit it... how ever did u try ur self ?? as I feel they would just fit in fine !!!
rebooting
ChotoCheeta.com
Old 05-09-2007, 06:24 PM   #5 (permalink)
slash_89
Posts: n/a
no dude just look at the distance between those slots, how will this fan fit, and to top it off no manual was provided,
and will the Core2Duo E4400 definately not work?
Old 05-09-2007, 06:55 PM   #6 (permalink)
Rubik's Uncle!!
Charan's Avatar
One confusion for me after seeing that BTX mobo.. why is the layout so differenent? looks like is to be placed opposite to the normal orientation. Can these mobos be placed in a normal ATX cabinets? Sorry for diverting form the topic.
Charan is online now
Old 05-09-2007, 07:06 PM   #7 (permalink)
assasin's Avatar
^^^ no u need BTX cabinets for these mobos.
assasin is offline
Old 05-09-2007, 07:12 PM   #8 (permalink)
Google Bot
Pathik's Avatar
Yup the BTX layout is very different from ATX to facilitate better air flow...
and Nope the BTX mobos cant be used with ATX cabbys and vice versa..
Pathik is offline
New Processor and Mobo for 20k nvidia Hardware Q&A 10 09-07-2007 01:41 PM
AMD mobo & processor ruturaj3 Hardware Q&A 4 03-06-2007 12:21 PM
Mobo+Processor executioner CPU / Motherboards 2 05-09-2006 04:49 PM
Best Processor And Mobo Under 10k arcticflare Hardware Q&A 12 27-08-2006 02:00 PM
mobo+processor 4 15k earthen61 CPU / Motherboards 5 21-12-2005 08:41 PM
