05-09-2007, 10:42 AM
Stay Silent!
LCD trouble
Help! My new samsung lcd monitor has started giving me troubles already.
As u can see in the attached pic, there r some THICK LINES on display. They r kind of hardware trouble. With no option left coz i had to sent an urgent mail, i slapped the monitor at the bak a few times....... n the display is fine at the moment.
What shud be the trouble and what shud i do??
I saw me running,
'Twas a long, long run.
But the view was so stunning,
And that made it so much fun... ©
05-09-2007, 09:31 PM
Mclaren F1 Long tail
Re: LCD trouble
Maybe you have got a lotta dead pixels on your lcd.The monitor should be replaced if it is under warranty.
Computers are like air conditioners. They work fine until you start opening windows.
06-09-2007, 12:34 AM
Re: LCD trouble
@enticer86 update display drivers,check the monitor on another pc.
06-09-2007, 07:29 AM
Stay Silent!
Re: LCD trouble
c if it had been dead lcds then it wont hav worked again...
n display drivers too- if they had been the issue then how come slapping the monitor worked?
I saw me running,
06-09-2007, 09:07 AM
Re: LCD trouble
if slapping the monitor worked then try a diff connecting cable or use a diff connector if u hav 2(dvi & d-sub).
06-09-2007, 09:58 AM
Stay Silent!
Re: LCD trouble
wich cable shud i change? theres one power supply cable n the other connects the the monitor
N yeah i tried to dc the pc - my monitor was on so it showed sm msg .."no signal detected" or smthin.. but the stipes were STIL there
I saw me running,
06-09-2007, 10:40 AM
Re: LCD trouble
change the cable that connects ur pc with ur monitor
06-09-2007, 10:45 AM
Stay Silent!
Re: LCD trouble
i told u... no use... coz even after disconnecting it my monitor works and shows the stripes
monitor works bole to it has sm inbuilt error messages n displays them
I saw me running,
06-09-2007, 05:15 PM
Re: LCD trouble
Boss rush to the nearest service centre.Seems to be some internal power supply problem.
06-09-2007, 06:40 PM
Stay Silent!
Re: LCD trouble
seems to me too
where r the senior members here?
I saw me running,
06-09-2007, 06:48 PM
Google Bot
Re: LCD trouble
Only option - Service center
06-09-2007, 08:46 PM
Stay Silent!
Re: LCD trouble
ohkie.. thnks bro fr the advice
I saw me running,
06-09-2007, 08:48 PM
M$™ Certified Spammer
Re: LCD trouble
call customer care im sure the lcd is defective something similar happened to me
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
06-09-2007, 08:54 PM
Stay Silent!
Re: LCD trouble
i got it from a relativ types- no box n all- cheap rates
I saw me running,
06-09-2007, 09:01 PM
Re: LCD trouble
o so i guess ur screwed
06-09-2007, 09:07 PM
Stay Silent!
Re: LCD trouble
no exactly.. i wil giv it bak to him.
he wil b obliged
*hopefully*
I saw me running,
06-09-2007, 09:18 PM
Re: LCD trouble
then where will u get ur new screen? i guess ull have to buy it
06-09-2007, 09:24 PM
Stay Silent!
Re: LCD trouble
i wil exchange with a properly workin thingy
not an issue
I saw me running,
06-09-2007, 10:19 PM
#19 (permalink)
Re: LCD trouble
not an issue
If it was so easy, you could have done so in the first place!
V.Prem Kumar
06-09-2007, 11:12 PM
#20 (permalink)
Re: LCD trouble
Thats how an LCD starts its end of the life cycle, my friend laptop developed the same bands 1......then 2.........3 then it was covering half the screen.......................I saw it happening over 1 month time & then it had to be replaced.
07-09-2007, 08:05 AM
#21 (permalink)
Stay Silent!
Re: LCD trouble
his workshop is pretty far n thts y i wantd to ask if there was smthin i cud do myself.
anywys- interesting place- his office i mean... at any point of time there are atleast a 1000 computers in various depts- the mouse dept, the keyboard area, the ram area
I saw me running,
08-09-2007, 09:58 AM
#22 (permalink)
Re: LCD trouble
So it seems that unlike CRT we can use a LCD for a maximum period of 3 years. (warranty period) I had to get mine replaced twice within less than one year. First time problem with brightness and buttons not working and second time monitor switching itself off!
V.Prem Kumar
08-09-2007, 10:36 AM
#23 (permalink)
Re: LCD trouble
Mostly yes but thats true even with CRT the life is 3yrs after that it looses or start loosing its brightness, sharpness & RGB channels start over lapping affecting the eyes badly.
Cheaper LCD wont last even 3yrs but for sure LCD have a life & within 3yrs u may upgrade to a better & bigger screen.
#24 (permalink)
Stay Silent!
Re: LCD trouble
just thinkin- lcd mein to its lik liquid crystals... but in CRT monitors there are pixels/... so when they hav to display black color, are they switched off?
I saw me running,
08-09-2007, 10:42 AM
#25 (permalink)
left this forum longback
Re: LCD trouble
so an LCD(TFT) life good only < 3 yrs
08-09-2007, 11:35 AM
#26 (permalink)
Re: LCD trouble
Yes.......................didn't you know that??? It will start loosing its brigtness by that time.
Your eyes are more precious, so u may not want to use it more than 3 yrs, our eyes adapt to any conditions & we don't see faults in our monitors until we compare it with a new monitor next to each other. MY 4yr samsung monitor is still running & till this jan07 I was using it quite well but its crap when I compare it with any new CRT monitor..........& when I compare it with my 20inch LCD then I wonder why the hell I was using all these 4 years.
There use to be some expensive Barco CRT monitors costing in those days 2.5 lakh upwards which had a life of 7 years, they were meant to be color accurate & very stable throughout their life cycle.
