Old 04-09-2007, 06:13 PM   #1 (permalink)
Question help me to select mobo n cpu
hi experts,
i am planing to buy a machine for myself.my budget is 45K,
usage - i am a web devloper..so most of time i do coding, surf the web..etc..n i download lots of movies in divx..so i watch those(my sony HT cant play divx )
n a bit of gaming..AOE,NFS HP, i guess shouldnt consider gaming at all as its not important
i have already decided abt few things..here are those
22" Dell LCD 19k( already ordered through dell ).
MS 4000 KB
MX518 Mouse (KB n mouse should come in 5k).
seagate 250 GB 3k
1GB DDR2 667 2K
now left is 16K
in this 16 K i need CPU+MB+Cabinet+ PSU( if genric one wldnt work)
i will add additional 1 GB RAM later n another big capicity HDD.
i really need dvi port and atleast 3 pci ports(modem, tvtuner, soundcard, may be later i remove Soundcard n add wi fi card).
n i wont overclock..n please no xfx 650i MB..i dont think i will find it in jaipur..
so guys what are my options..i really need a stable machine..n i will prefer components which makes less noise
Thanks in advance
lokeshv is offline
Old 04-09-2007, 07:27 PM   #2 (permalink)
Default Re: help me to select mobo n cpu
Rashi deals with XFX and Asus.
Look here :
Rashi Peripherals Pvt Ltd. 320 Navjeevan Complex,
Railway Station Road,
Jaipur - 302 206.
Tel No.: +91 - 0141 - 2370933/2370949 Fax No.: +91 - 0141 - 2370933 Email : jaipur@rptechindia.com
sashijoseph is offline
Old 04-09-2007, 10:31 PM   #3 (permalink)
dont think they will have ..they still quote MX518 ~2500..so it really sucks here
n 650i have just 2 pci..pls suggest me ATX mobo
can somebody suggest me AMD config ??
lokeshv is offline
Old 04-09-2007, 11:22 PM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
May be you didnt pay attention to the sticky thread http://www.thinkdigit.com/forum/showthread.php?t=66140
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 04-09-2007, 11:34 PM   #5 (permalink)
actually i did..but i think i cldnt find there what i am looking for ..as you wld have notice i dont need much power.. so i posted this thread..if somebody can help me in deciding the MB n CPU...
may be i should post this in that thread ...
lokeshv is offline
Old 05-09-2007, 12:27 AM   #6 (permalink)
moshel's Avatar
well u cud check out mobos based on the 945 and 946 chipsets, pretty basic and cheap.
As for the DVI port, i think u will need to fit an extra PCI-E card. u can go for 8500GT pretty decent performance at 5-6k.
so,
945/946 mobo abt 4K
a good C2D processor for abt 8k. sorry dont knw which model
hmm...thats already 12K. so if u cannot expand ur budget then go for 7300GT shud be between 3-4K.
moshel is offline
Old 05-09-2007, 10:36 PM   #7 (permalink)
Thanks moshel
can you pls suggest me mobo the only one i can find on itwares is D946GZIS
which mATX..
should i go for 8400GS or 7300GT ?
Thanks
hi guys ..i guess i will go with xfx 650i mobo.. will ask rashi ppl to get me on order.
now pls suggest me CPU n gfx card
c2d 4400 + 8400 GS ? or may be 8500 GT
or
E6550 + 8400 GS ?
Thanks
ok finally bought this today..will add gfx card later
AMD 5600
ASUS M2A-VM - 10.9 k
2 GB kingston - 3.5k
zebronics bijli cabinet-1.2k
zebronics pure platinum 500 w - 2.2k
seagte 320GB 16mb buffer 3500
also ordered logitec MX518 mouse - 1.5k
thank guys for all help
lokeshv is offline
Old 05-09-2007, 11:20 PM   #8 (permalink)
moshel's Avatar
Congrats on ur new system.
btw dont even think abt going for the 8400 card.
8500GT is the minimum u shud opt for. or even 7600GT is good. If budget permits, 8600 shud be good in the sub 10K category.
moshel is offline
Stuck when I select a folder Chrono Cr@cker Software Q&A 3 11-05-2007 10:03 AM
Pls help me to select a smartphone !!! sainit Mobiles and Tablets 21 08-04-2007 02:17 AM
Help me to select a phone jam Mobiles and Tablets 21 14-08-2006 02:00 AM
which platform do i select? iinfi QnA (read only) 4 05-07-2005 07:33 PM
Help me select a GAME!!! neonet2004 Gamerz 5 13-08-2004 05:53 PM
