Old 04-09-2007, 01:47 PM   #1 (permalink)
Smile Autometic shutdown
My system is autometically shuting down after 40 to 60 seconds.
and sometime it is also restarts autometically
Please help me to sortout the problem
My system configuration is:
915 intel chipset Main Board 256 MB DDR 400 fsb RAM 40 GB SATA HDD 250 Watt SMPS
dghosh033 is offline
Old 04-09-2007, 01:49 PM   #2 (permalink)
shantanu's Avatar
Default Re: Autometic shutdown
most probably your SMPS is faulty.. try another one or get it repaired.. well a new normal 400 watt SMPS costs about 350/- so better get a new one or first bring your friend's and test it..
shantanu is offline
Old 05-09-2007, 12:55 PM   #3 (permalink)
Thanx I tried your solution but still problem not solving
I have also checked all 4 RAM Slots with diffrent RAMs
System is shuting down even if BIOS is open(in the BIOS screen)
This means it is not any OS related problem and any of the Hardware is
faulty.
Please help
Old 05-09-2007, 12:57 PM   #4 (permalink)
shantanu's Avatar
okey.. that means , it maybe any other hardware... most probably yur CPU is over heating.. now try to open your cabinet and just tighten the heat sink over your processor, it will be better if you take the heatsink and fan out and re-install it..
and there are plenty of threads running.. so first search the forums before creating a new thread ..
shantanu is offline
Old 05-09-2007, 01:05 PM   #5 (permalink)
Hey thanx for quick reply but I already searched and not found any
anyway let me try this solution, by the way can you tell me whats the cout of a new 915 intel chipset Main Board
Old 05-09-2007, 01:14 PM   #6 (permalink)
shantanu's Avatar
did you search ? see the bottom of this page.. there are 5 threads listed and about 2 i remember which i started..
well coming back to topic.. do you want to know the cost of main board ?
shantanu is offline
Old 05-09-2007, 01:34 PM   #7 (permalink)
Rubik's Uncle!!
Charan's Avatar
hmmm 915 Mobo .. that means you are using a presscot processor. Check the temp
Charan is online now
Old 24-09-2007, 08:57 PM   #8 (permalink)
Unhappy Re: Autometic shutdown
automatic shutdown my pc when click dontsent option
nirjhar is offline
Old 29-09-2007, 01:49 PM   #9 (permalink)
nirjhar is offline
cant shutdown pc tweety_bird_bunny QnA (read only) 6 13-09-2006 11:30 AM
Windows SHUTDOWN Problem, system freezez on shutdown screen catch_maxi Software Q&A 2 16-03-2006 07:38 PM
"improper shutdown" msg on proper shutdown mvishnu QnA (read only) 2 26-02-2006 06:50 PM
NO SHUTDOWN! gary4gar Software Q&A 2 09-02-2006 02:03 PM
Autometic signout from Y! Messenger!! Choto Cheeta Software Q&A 7 08-12-2005 08:10 PM
