Old 04-09-2007, 03:38 AM   #1 (permalink)
Techie By Heart
mavihs's Avatar
Post LCD Monitor 19inch-budget Rs10,000
i wanted to take a LCD monitor.can u guys advise me 1 in the range of Rs.10,000. i wanted for gaming & watching movies. want a 19inch 1.
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline
Old 04-09-2007, 06:05 AM   #2 (permalink)
Gizmo Freak !
spitfire's Avatar
Default Re: LCD Monitor 19inch-budget Rs10,000
for watching movies and gaming widescreen is best
Take a look at Viewsonic VX1932wm 19" Model
Its with 2ms gtg response time and with a dvi port
Its available in kolkata @ rs 10,500
Its a great monitor..worth considering I must say
spitfire is offline
Old 04-09-2007, 07:22 AM   #3 (permalink)
M$™ Certified Spammer
entrana's Avatar
u cud try asus and dell, or even samsung
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Old 04-09-2007, 11:59 AM   #4 (permalink)
If the dvi port is not a problem, then you can go for ViewSonic VA1912w.........retails at around 9.5 k in Mumbai!!!!!!!!
If u dont know, dont guesss.... ASK!!!!!!!!!!!
saud_khan is offline
Old 05-09-2007, 12:28 AM   #5 (permalink)
Techie By Heart
mavihs's Avatar
so which 1 is better??
mavihs is offline
Old 05-09-2007, 06:41 AM   #6 (permalink)
Gizmo Freak !
spitfire's Avatar
This is the latest prce of Viewsonic price in kolkata !
17" VA 1703WB - 7800
17" VA 1703B - 7900
19" VA 1903WM - 8700
19" VA 1912WB - 8700
19" VA 1912WM - 8700
19" VG 1930WM - 9800
19" VX 1932WM - 10300
20" VG 2021M - 13500
22" VX 2235WM - 17000
22" VX 2245WM - 18000
If your budget permits then surely go for 1932wm...its way better with 2ms response time.Absolutely brilliant display
spitfire is offline
Old 07-09-2007, 01:55 PM   #7 (permalink)
DD3030's Avatar
Any idea whether VX922 is available and what is its' price? I know it is not wide.
Also, can anyone tell whether VX1932WM is available at Lamington Road and at what price?
DD3030 is offline
about 19inch lcd widescreen micky00747 TVs / Monitors 1 23-07-2007 11:13 AM
A mob....Budget:7k to 8k thewisecrab Mobiles and Tablets 34 14-06-2007 03:41 PM
Best phone for Rs10,000 +/- 2000/-. It's a little urgent. baccilus Mobiles and Tablets 23 22-11-2006 03:30 PM
Low Budget PC gauravakaasid QnA (read only) 6 21-07-2006 12:34 PM
Monitor and Monitor Power Light is blinking aathif QnA (read only) 4 21-05-2005 05:20 PM
