I wanna buy C2D E6550.....but i want a decent and economical mobo for this processor.........Graphics no issues as i have an XFX 8600 GT graphics card..........hence i want a mobo with neat features and a bit easy on the pockets as well.............Please suggest some good boards...........Thanx!!!!
If u dont know, dont guesss.... ASK!!!!!!!!!!!
e6750 costs 8k
hey guys whats better xfx650i ultra or asus p5nesli if i DONT WANT SLI
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
is it possible to over clock a bit with the stock fan for the c2d e6550 or e6750????? and is the latest version available which does not require a bios update???? if yes, what is the way to recognize that!!!!!!!!!
Originally Posted by entrana
e6750 costs 8k
not in my budget dude!!!!! i think i will have to go with c2d e6550........it isnt that bad compared to e6750..........is it????????
Reason: Automerged Doublepost
Yes it is.It's the P03 bios revision.
To recognise it you'll need to boot up and note the bios string for a P03 at the end.
Just tell your dealer to connect the proccy,ram,and graphics card and show the display.
Any other way to identify the bios upgrade if the dealer does not agree to comply with the above conditions!!!!!!! Any identifications on the box????? and may i know since when xfx start to ship the upgraded mobos........i think that may help as well!!!!!!!
@saudkhan In some places it already has.. And the 6550 aint bad
@entrana if u dont need sli then save 2k and get the xfx 650i ultra..
@gigacore the asus p5n e sli is a very good board
@pathiks well i dont need sli, but i read reviews saying xfx 650i is unstable and bad, real real bad
Any member using this board here???????
didnt get ya???????
