Old 02-09-2007, 08:28 AM   #1 (permalink)
jatt's Avatar
Exclamation mp3 problem please help
i have a mp4 which gives me a format error on some of mp3 songs and amv songs but some plays well whats the problem please help me is it any problem related with hardware or another? what is solution please guide me thanks in advance please help me out dear friends its urgent for me please if anyone
any one help me out yaar
ਨੋ ਗਰਲ ਫਰੈਂਡ ਨੋ ਟੈਂਨਸ਼ਨ,no girlfriend no tension,website: Punjabi.c-o.in,forum: punjabiteacher.co.cc
jatt is offline
Old 02-09-2007, 08:31 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: mp3 problem please help
Check the bit rate supported by the player... see MP3 or any other will have different bit rate according to which its been riped from the ACD...
may be the File you wants to play is bellow or avobe the bit rate supported by the player which u have....
Bits rates are like 32bit / 64bit / 128bit or more high like 320bits ...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 02-09-2007, 08:33 AM   #3 (permalink)
jatt's Avatar
no brother i have already check all properties of all songs but its same there is no difference in between bit rate
jatt is offline
Old 02-09-2007, 08:36 AM   #4 (permalink)
Rebooting
OK.. I'm out of suggestion then time to take it to ur nearest service center and ask them the same question may be a hardware problem
rebooting
ChotoCheeta.com
Old 03-09-2007, 06:26 AM   #5 (permalink)
jatt's Avatar
thanks i will try that a lot of thanks friends
jatt is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
