01-09-2007, 06:39 PM
RajU
Strange problem with the cursor
Cursor is moving automatically to the right, I didn't touched my laser mouse, it is all happening all by itself, cheaked for virus, nothing found
nO pAST, nO fUTURE, Just Now
config: *2007 YZF-R1*
E6750 @3.2GHz; asus p5k-vm; 2gb JETRAM @800MHz(4-4-4-12); 250gb seagate; ZEB 500w; xfx 9600gt
01-09-2007, 06:56 PM
in search of myself
Re: Strange problem with the cursor
Also happened with me. May be problem in driver.
Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga" :lol:
01-09-2007, 07:18 PM
RajU
Or hardware prob. By the way, did you installed new driver or changed it
01-09-2007, 07:48 PM
in search of myself
Nothing. Because the problem is not so common.
Remove the driver if you installed and then check if it is working fine
Unban Praka123
01-09-2007, 07:53 PM
RajU
Ok, I will see that, thank u
01-09-2007, 08:02 PM
@786
Which mouse it it?
Logitech basic optical has such issues. Mainly due to surface incompatibility.
Try some cloth mouth pads.
if u want i can send u the "usbport.sys" file for win x86.
G3: XPS M1530 |
FZ 16.
01-09-2007, 08:10 PM
RajU
Mine one is Microsoft's Basic optical mouse
01-09-2007, 08:16 PM
M$™ Certified Spammer
it cud be in contact with air, or either ur using glass, use a paper based material or wooden ittl do fine mouse pads will also be good
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
Cool and Calm
i hav experienced too.....but i am sure its not a h/w or driver problem...
yes.....^^^ "surface incompatibility"
When Roger's at play, opponents pray..!!!!! :twisted:
01-09-2007, 08:20 PM
happened to me lots of times try it put ur optical mouse up its gonna move to the right automatically,if it does error with surface doesent happen all the times
02-09-2007, 12:04 AM
RajU
I'm using it on wooden plank that usually comes with computer tables though it has become plain and a very little bit shiny but previously(not more than a week) I had used Techcom optical mouse which didn't show up like that. Now I don't have that mouse or I would have tested that......opps,,, sorrry that mouse was not a usb mouse & my new MB dosen't have the old connector for that, my bad
02-09-2007, 01:08 AM
Rubik's Uncle!!
Even my mouse cursor moves.. and I have a MS optical mouse.. Just check by changing the mouse pad.
02-09-2007, 02:02 AM
02-09-2007, 10:03 AM
RajU
^^yeh, you might be right.........hey devils, go away, don't play with us and our computers, go play with slugger........he.....he.........
02-09-2007, 08:52 PM
u shudnt use on glossy wood what i do is just place a notebook over it mouse pads make it worse for me i just put a long register below it
