Old 31-08-2007, 07:42 PM   #1 (permalink)
bigdaddy486
Posts: n/a
Default What should ibupgrade?
I have c2d e6300
intel dg965wh
nvidia 6200 tc 256mb
samsung samron monitor CRT
seagate 80 gb hdd 7200 rpm
512 mb ddr2 533mhz ram
Old 31-08-2007, 07:45 PM   #2 (permalink)
in search of myself
CadCrazy's Avatar
Default Re: What should ibupgrade?
Please clarify what you want
Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga" :lol:
CadCrazy is offline
Old 31-08-2007, 08:01 PM   #3 (permalink)
Cool G5's Avatar
Do u mean upgrade?If so update gfx card(get one from nvidia 8 series).Also buy a large hard disk,if u want.
Cool G5 is offline
Old 31-08-2007, 08:46 PM   #4 (permalink)
Cool and Calm
abhi_10_20's Avatar
upgrade ur ram 1st!!! 1gb is minimum these days....
When Roger's at play, opponents pray..!!!!! :twisted:
abhi_10_20 is offline
Old 31-08-2007, 09:27 PM   #5 (permalink)
in search of myself
CadCrazy's Avatar
Well it all depend on your budget and what kind of work you do on your pc.
Unban Praka123
CadCrazy is offline
Old 31-08-2007, 10:31 PM   #6 (permalink)
dOm1naTOr's Avatar
+1 for abhi_10_20
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 01-09-2007, 10:39 AM   #7 (permalink)
bigdaddy486
Posts: n/a
i am a average gamer and i want to upgrade my pc to run future games like nfs pro street. plz post the prices also for hardwares which i upgrade. don't care the budget but not very high because i am a strictly average gamer.
Old 01-09-2007, 10:49 AM   #8 (permalink)
dOm1naTOr's Avatar
Get another 512 Mb DDR2 transcent 667 , but u shud use them in single channel.
cost is 0.8~1k
For da Graphics Card there are lotz of choice and its ur budget that matters.
7600GT : 5.6k
8600GT : 6.5k
7900GS : 8.5k
8500GT : 4.5~5k
G3: XPS M1530 |
FZ 16.
Old 01-09-2007, 02:06 PM   #9 (permalink)
bigdaddy486
Posts: n/a
Thanks a lot.........
Old 02-09-2007, 08:55 PM   #10 (permalink)
M$™ Certified Spammer
entrana's Avatar
we can help u if u tell us ur budget
id suggest u upgrade ram to 2gb and gfx at least 8600gt from xfx worth 7k
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Old 02-09-2007, 10:30 PM   #11 (permalink)
Google Bot
Pathik's Avatar
1..
Btw u shd remove the 6200 tc neways.. X3000 wit updated drivers ll perform better..
Pathik is offline
Old 02-09-2007, 10:49 PM   #12 (permalink)
bigdaddy486
Posts: n/a
If my budget is 10,000?
Old 02-09-2007, 10:58 PM   #13 (permalink)
dOm1naTOr's Avatar
@bigdaddy486
7900GT, X1900XT or even 7900GS. Much better tha 8600GTS.
see this nd decide
http://img515.imageshack.us/my.php?i...6855318ik1.png
but first upgrade ur ram to atleast 1Gb, but to utilize such cards ull need 2 GB in dual channel.
G3: XPS M1530 |
FZ 16.
Old 02-09-2007, 11:41 PM   #14 (permalink)
Google Bot
Pathik's Avatar
If i had 10k i wd sell my 6200tc and 512mb ddr2 giving me total 12k to spend.. Then get a 8600 gt 2*1gb ddr2 667mhz a hdd maybe
Pathik is offline
Old 03-09-2007, 03:37 PM   #15 (permalink)
bigdaddy486
Posts: n/a
2 GB in dual Channel means 1 gb ram each in two slots?What's the price of 7900GT? What's the price of 1 GB DDR2 Ram?
Old 03-09-2007, 06:58 PM   #16 (permalink)
Google Bot
Pathik's Avatar
I gb ddr2 667 is arnd 1.6 to 1.8k..
Pathik is offline
