Old 30-08-2007, 10:45 PM   #1 (permalink)
arun77574's Avatar
Question Will my motherboard support GeForce 8600GT
Hi guys,
I have a Gigabyte 81915ME GL motherboard, Intel Pentium4-3.00Ghz processor and 1GB DDR ram. I've planned to purchase a new gfx card for my PC and i'm not able to find out if my motherboard would support the gfx card i've planned to buy. Could someone guide me through this. Im planning to go for GeForce 8600GT 256mb or GeForce 7600GT 256mb.
arun77574 is offline
Old 31-08-2007, 12:07 AM   #2 (permalink)
slugger's Avatar
Default Re: Will my motherboard support GeForce 8600GT
AFAIK ur mobo duz have a PCIe slot
so der shud b no problem usin d card on ur mobo
if u r not sure if PCI-e slot is der or nt, den just check ur moobo manual
but i think PCIe is present on ur mobo
slugger is offline
Old 31-08-2007, 12:46 AM   #3 (permalink)
NP : Crysis
xbonez's Avatar
if pci-e is there then yes it supports 8600
if pci-e isn't there, then no it doesn't supports neither 8600 nor 7600
xbonez is offline
Old 31-08-2007, 04:42 AM   #4 (permalink)
Nav11aug's Avatar
ur mobo has a PCIe x16. Enjoy
herez the product's online page: http://www.gigabyte.in/Products/Moth...ProductID=1925
http://www.last.fm/user/NOLFxceptMe/
http://naveendageek.blogspot.com
Back after a long time. And well, EndSems screwed up as usual :)
Nav11aug is offline
Old 31-08-2007, 08:20 AM   #5 (permalink)
slugger's Avatar
7600 has an AGP version
slugger is offline
Old 31-08-2007, 06:07 PM   #6 (permalink)
arun77574's Avatar
yes my mobo has a PCI-e slot. i'm already having a Geforce 6200 Turbocache card in it. it also has an AGP slot and a G.E.A.R slot
Old 31-08-2007, 08:49 PM   #7 (permalink)
Cool and Calm
abhi_10_20's Avatar
hmm...what's the price of both these cards?
When Roger's at play, opponents pray..!!!!! :twisted:
abhi_10_20 is offline
Old 31-08-2007, 09:18 PM   #8 (permalink)
NP : Crysis
xbonez's Avatar
what's a G.E.A.R. slot??? hearing about it first time
xbonez is offline
Old 31-08-2007, 09:33 PM   #9 (permalink)
slugger's Avatar
both shud cost between 6k-8k
+1
slugger is offline
Old 31-08-2007, 09:50 PM   #10 (permalink)
dOm1naTOr's Avatar
wow, the mobo has both PCIE nd AGP slots...
heard dat asrock once has such models, but dun knew bout Gigabyte
Whats dt GEAR slot?
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 31-08-2007, 10:15 PM   #11 (permalink)
Cool G5's Avatar
Post Re: Will my motherboard support GeForce 8600GT
+1
Cool G5 is offline
Old 01-09-2007, 09:29 PM   #12 (permalink)
i dont expect 8600 to perform to full potention in this board . it's got a pcie x4 slot . its only expanded to the physical size of a pciex16 slot.
the board is based on intel 915 GL chipset which doesnt officially support pcie x16 . they have somehow got both pciex4 and agp slots ( GEAR SLOT ).
neway , there may be no guarentee that the card WILL be supported. u have to ask if some1 has tried and/or contact support team of gigabyte . but even if it does the card will under perform..
sagargv is offline
Old 02-09-2007, 10:51 AM   #13 (permalink)
Nav11aug's Avatar
so.. tzh the answer fr whz the GEAR slot?
Nav11aug is offline
Old 02-09-2007, 12:36 PM   #14 (permalink)
Google Bot
Pathik's Avatar
Asrock had many such PCIe+ AGP boards released wen AGP was being phased out..
btw +1 to the GEAR qn..
Pathik is offline
Old 02-09-2007, 01:58 PM   #15 (permalink)
yes . the agp slot they have "constructed" for the board is called GEAR slot by them .
sagargv is offline
Old 02-09-2007, 08:56 PM   #16 (permalink)
M$™ Certified Spammer
entrana's Avatar
o, GEAR slot ei
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Old 02-09-2007, 09:57 PM   #17 (permalink)
@sagarv
ummmm.....r u sure abt tat..
i have the same mobo...
the pcie slot is a 16x one and not a 4x slot....
guess 8600gt shud work....
i chckd out dis site.....
http://www.intel.com/support/motherb.../CS-012066.htm
elator is offline
Old 02-09-2007, 10:50 PM   #18 (permalink)
bigdaddy486
Posts: n/a
Will it fit on intel DG965WH?
Old 02-09-2007, 10:55 PM   #19 (permalink)
dOm1naTOr's Avatar
@bigdaddy486
yup, itll fit on any mobo with PCIE slot.
G3: XPS M1530 |
FZ 16.
Old 03-09-2007, 03:23 PM   #20 (permalink)
bigdaddy486
Posts: n/a
Will it work?
Old 03-09-2007, 04:32 PM   #21 (permalink)
Nav11aug's Avatar
lol. It will .. try out
Nav11aug is offline
Old 08-09-2007, 11:51 PM   #22 (permalink)
arun77574's Avatar
I'm sorry guys for not answering your questions for a long time. here is the link which shows what my mobo has got in it.
http://www.giga-byte.com.tw/Products...=GA-8I915ME-GL
And here is the link which says what is G.E.A.R.
http://www.giga-byte.com.tw/Support/...x?NewTechID=81
Old 09-09-2007, 12:34 AM   #23 (permalink)
Nav11aug's Avatar
[U] That was the page i referred to when I gave my answer
Nav11aug is offline
Old 09-09-2007, 03:37 PM   #24 (permalink)
Originally Posted by elator
@sagarv
dude , u have intel d915 mobo based on 915G ( not 915GL ) chipset which supports full pcie x16 . u wont have any probs . but the OP has a gigabyte mobo with a pciex16 slot ( acutally x4 but its lengthened to the size of a x16 slot) and the gigabyte mobo runs it at x4 link speed which will degrade performance . the gigabyte mobo OP has is based on 915GL which officially doesnt support pciex16 . no probs with intel d915GAV.
sagargv is offline
8600GT or 8600GTS or 8600GT Fatality bajaj151 QnA (read only) 31 12-08-2007 08:38 PM
Will Mercury 845GL motherboard support 512MB DDR RAM AT 333/400 MHZ jiteshbhimani Hardware Q&A 8 07-07-2007 08:59 PM
motherboard with good grafix support bkpeerless Hardware Q&A 5 03-02-2007 11:01 AM
Will GeForce 6600 AGP card run on Mercury PI845GLM-AGP 4x Motherboard topgear Hardware Q&A 24 25-01-2007 12:12 AM
Motherboard Support for Storage Capacity techtronic Hardware Q&A 1 23-06-2006 01:29 PM
