Laptop mouse died :( :( help
Hi
My laptop mouse has suddenly stopped working. it is going in weird directions.. if i take my finger to the right then it will not move at all. if i move in the left then it goes to the right and so on... just ging randomly
this is the same scenario in windows xp and ubuntu which makes me think that it is some hardware related issue
please suggest what is the problem and how it can be slved
thanks
Registered Linux user number 400618
Check this mouse on another computer to verify whether it works or its time for a new one
Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga" :lol:
Never heard of this inbuilt mouse. I am sure you must be talking about joystic kind of button on keyboard or Touch Pad. If this is the case then take it to service center. Nothing can be done about it.
Unban Praka123
@cadcrazy: he is referring to the touch pad mice on the laptops
USB is the only mouse we can use on laptops. You can't use ps/2 .
Unban Praka123
if u want u can just plug in a usb mouse or if u really want just go to the service center
the service cetner sites are usually listed on asus india website
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
