Old 30-08-2007, 07:23 PM   #1 (permalink)
Ankush_is_here's Avatar
Default May i use thermal paste on my processor and how to use
Hi guys pls tell me how i will use thermal paste on my intel 2.4 processor.
And can i directly use my pc after pasting without wait for some time..
`·.¸(¨`·.·´¨)Keep
(¨`·.·´¨)¸.·´ Smiling!
`·.¸.·´ Ankush Gupta
Ankush_is_here is offline
Old 30-08-2007, 08:39 PM   #2 (permalink)
in search of myself
CadCrazy's Avatar
Default Re: May i use thermal paste on my processor and how to use
Why you want to use the paste???
Anyway thermal paste is applied between cpu & CPU cooler fan in order to make full contact between two which is necessary for better heat transfer. Just apply the paste on top of CPU and then install cooler.Thats it.
Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga" :lol:
CadCrazy is offline
Old 30-08-2007, 10:39 PM   #3 (permalink)
slugger's Avatar
detailed explanation
How To Correctly Apply Thermal Grease
KISS explanantion
Applying and removing Thermal grease
@CADCrazy
us yaraana-wale post ka response
ek aur thread tha us thread ke neeche hi
slugger is offline
Old 31-08-2007, 07:34 AM   #4 (permalink)
Guys Pls tell can i directly use my computer after pasting on processor or wait for dry of paste applied on processor.
`·.¸(¨`·.·´¨)Keep
Old 31-08-2007, 08:24 AM   #5 (permalink)
slugger's Avatar
ya u can start using it immediately
if any thing, the wet grease will actually improve heat transfer
slugger is offline
Old 31-08-2007, 05:23 PM   #6 (permalink)
The Frozen Nova
casanova's Avatar
I heard it is very risky as if even a milimeters gap remains and it can burn the proccy. Please enlighten on it.
@Slugger,
Thanks for the links. Will be useful after enlightment.
www.nerdweed.blogspot.com
casanova is offline
Old 31-08-2007, 05:53 PM   #7 (permalink)
slugger's Avatar
if u apply d grease uniformly and generously there shud d no danger of ne air gaps being present
(use a visitng card to spread it evenly over d processor and heatsink surface)
and ne way heatsink is press-fitted over the processors, so there is pretty much no chance of any gap remaining, esp after grease application
just remember
uniformly..........generously..........carefully and u shud b fine
slugger is offline
Old 31-08-2007, 09:32 PM   #8 (permalink)
wait for 30-45 mins then assemble it.
And dont apply thermal paste if u r not facing any heating problem, u may damage the processor .
Faun is offline
Old 31-08-2007, 09:40 PM   #9 (permalink)
slugger's Avatar
wat parameters have u taken into considerations b4 arriving at this magical number 30-40 mins
applying thermal grease damages d processor
go tell this to those mfg Artic Silver
slugger is offline
Old 31-08-2007, 09:47 PM   #10 (permalink)
in search of myself
CadCrazy's Avatar
is it really so.Beyond my imagination
Unban Praka123
CadCrazy is offline
Old 31-08-2007, 11:09 PM   #11 (permalink)
The Frozen Nova
casanova's Avatar
Thx slugger for the uniform generosity you showed carefully.
Practicing it so that I can try it that way.
casanova is offline
Old 31-08-2007, 11:39 PM   #12 (permalink)
dOm1naTOr's Avatar
If it were some hours then it wud have been much boring...
Its actually damages our purse
nyway thnx slugger for da link, its really helpful.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 01-09-2007, 11:24 PM   #13 (permalink)
I was just telling the instruction given with the leaflet.I hav applied it on my frens comp.
And i never said to condemn using Thermal paste/grease/pad/whatever, my point was that applying these things just for fun is not worth it (if u r not facing any overheating problem and just curious to apply a better paste in place thinking u can lower few centigrades then its a pure risk)
u all act like herd sometimes
Faun is offline
Old 01-09-2007, 11:47 PM   #14 (permalink)
slugger's Avatar
d00d u r claiming to have seen this instruction on sum leaflet that ur friend had w/o really giving n e supporting evidences
y dont u show us d url of d document on thermal paste mfg's Co website
Cos always have online copies of documents
d member has been sufficiently adviced to read d instructions given in d url provided and has been asked to be very careful
let d thread starter determine weather it is worth it or not
y r u decdin 4 him weather it is worht it or not?
it is not as if he is doing any thin dat cud get him booked under IPC
slugger is offline
Old 02-09-2007, 12:19 AM   #15 (permalink)
posting the URL is not possible as i dont hav that leaflet with me, threw it a the very moment i applied the pad.
Even i dont remember the brand cuz it was not from a well known manufacturer(like arctic silver).
Just think abt it n u can make out wat waiting for a few mins means to ur processor die.
1. It may wrap around the other parts and prevent the heat dissipation (so use less and make a very fine layer and try to make it somewhat dry before assmebling).
2. For thermal pad u need to first let the other end grip the die before u remove the poly covering or else it all will tear out uneven and then it will be too hard to place it without making a mess out of it.
yeah the member is a newbie, thanks for providing him the necessary links.
Still i liked to share my experience. I hav seen instances where things went wrong just for plain fun making with things u shouldnt.
Faun is offline
Old 02-09-2007, 10:34 PM   #16 (permalink)
Pee into the Wind...
shady_inc's Avatar
Do I need to apply thermal paste if I put my processor in new motherboard??The processor has been in the old motherboard for more than 2 years now with thermal paste on.So,do I need to remove this layer of thermal paste??If yes,how??
@ Ankush_is_here: Hope you don't mind me posting this query in your thread.I was about to make a new thread with my query when I spotted yours.
Life is as complicated as you say it is.
shady_inc is offline
Old 02-09-2007, 10:41 PM   #17 (permalink)
Google Bot
Pathik's Avatar
Well some people may not agree wit me but i just scrape off the dried old thermal paste with my nails and wipe it with a cloth..
A better method wd be to clean it wit alcohol
Pathik is offline
Old 02-09-2007, 11:01 PM   #18 (permalink)
dOm1naTOr's Avatar
+1 for alcohol. it makes sure there isn't even tiny particles left on surface and dun do scratches on surface unlike some metal instruments.
G3: XPS M1530 |
FZ 16.
Old 02-09-2007, 11:08 PM   #19 (permalink)
slugger's Avatar
every time you seperate the processor from the (heatsink+fan) combo you must apply a new layer of thermal graese after properly removing the old layer both from the processor surface and the heat sink
the thermal paste ensure that a continous contact surfac is mantianed between the processior and heatsink for unform heat transfer from the entire processor surface.
the moent you take out the haetsink from the processor you break this contimuity thereby rendering the OLD thermal paste useless
slugger is offline
Old 02-09-2007, 11:26 PM   #20 (permalink)
Thumbs up Re: May i use thermal paste on my processor and how to use
I used colin soaked cloth to clean both surfaces, and that's the best available option to clean , wat do u ppl say ?
dabster is offline
Old 02-09-2007, 11:29 PM   #21 (permalink)
slugger's Avatar
In this case you first have to clean the rests of thermal compound. Use a cotton swab with isopropyl alcohol (isopropanol). This kind of alcohol is purer (doesn’t contain water) and can be found at electronics equipments stores or drugstores.
SOURCE
slugger is offline
is Thermal paste really needed? anilmail17 QnA (read only) 3 30-05-2007 03:29 PM
Thermal paste srinivasbg Hardware Q&A 12 21-05-2007 01:18 PM
No Thermal Paste !! adorablesrini Hardware Q&A 9 24-02-2007 01:16 AM
Why we have to apply thermal paste? nithinks QnA (read only) 9 18-07-2005 02:27 AM
Thermal Paste Applied. navisangha QnA (read only) 5 21-06-2005 09:35 PM
