Old 30-08-2007, 03:50 PM   #1 (permalink)
Default Samsung Sucks...help me !!
Hey, i have a Samsung 18x DVD Writer, n hell, it takes around and hour to burn a 16x DVD. wot am i supposed to do? plz help me folks!!
apacheman is offline
Old 30-08-2007, 04:20 PM   #2 (permalink)
slugger's Avatar
Default Re: Samsung Sucks...help me !!
dats probably bcos u runnin in PIO mode
change it 2 UDMA hopefully ur problem wil b sorted
slugger is offline
Old 30-08-2007, 04:31 PM   #3 (permalink)
well, it luks greek n latin 2 me, how do i change it to UDMA mode?
Old 30-08-2007, 04:43 PM   #4 (permalink)
AJJU
azzu's Avatar
yup how do i change?
I love and Live to Design
azzu is offline
Old 30-08-2007, 06:54 PM   #5 (permalink)
first of all
In Nero, do u keep the option "cache files smaller than 64K" checked?
It shpuld be checked.
It prevents larger files copied to C drive ,or nero temp dir, b4 burning.
try this.
ashnik is offline
Old 30-08-2007, 07:02 PM   #6 (permalink)
damn busy...
utsav's Avatar
go here
change pio transfer mode to UDMA
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 30-08-2007, 07:39 PM   #7 (permalink)
slugger's Avatar
@utsav
d00d ur tut is gud but i wud suggest apacheman to change his drive to UDMA mode like this
http://www.thinkdigit.com/forum/show...68&postcount=6
u may also wan 2 check ur BIOS settings to c if UDMA mode is enabled from there, because if it is disabled der den nothin will work
first check ur BIOS and den follow d procedure given in d link above
slugger is offline
Old 30-08-2007, 09:09 PM   #8 (permalink)
damn busy...
utsav's Avatar
ur also right
www.techjunkiez.com
utsav is offline
Old 31-08-2007, 02:35 AM   #9 (permalink)
r these the actual solutions for de problem i'm facing? or is my Writer defective?
by de way, i've checked my secondary IDE drive, in te transfer mode tab, it says DMA if available for both Device 0 n Device 1, and Ultra DMA Mode 5 for current transfer for Device 0.
WHAT am i supposed to do?
plz help me out guyz...
Whr r u folks "Slugger, help-is-here, imav, shantanu, gx-saurav, infra red dude etc etc".......
HELP ME OUT..PUH-LEEZ !
Old 31-08-2007, 08:52 AM   #10 (permalink)
slugger's Avatar
i suggest u take ur drive to a friends place (who is facin no comp problems ) and get try buning sum disks der b4 drawing a conlcusion
well if UDMA was disabled den u wud have faced similar problems
but it seems dat it is not d case
slugger is offline
Old 01-09-2007, 02:52 AM   #11 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
Have u tried switching media and burner app?
jin files ka koi server nahi hota unka bittorrent hota hai
chesss is offline
Old 01-09-2007, 08:52 AM   #12 (permalink)
Still Shining!
Lucky_star's Avatar
Click on THIS and your samsung will be back to life again.
Nokia N86 8MP
Lucky_star is offline
Old 06-09-2007, 06:28 AM   #13 (permalink)
yo, thanx buddy..ur stuff reeely helped me... i jus burned a dvd in jus flat 5 mins...phew...wonder!
but tell me 1 thin', wot was de prob?
n yea, i ain't selling dis dtuff 4 a very very looong time...!
Old 06-09-2007, 10:14 AM   #14 (permalink)
slugger's Avatar
it basically automate d procedure dat i was askin u to do manually
ur drive was workin in PIO mode when it is capable of workin in UDMA mode
so all it did was to re-eanble UDMA mode without u havin to enter Device Manager
http://forum.digital-digest.com/showthread.php?t=61905
slugger is offline
Blu Ray Sucks!!! Vivek788 Open Source 23 05-08-2007 11:05 PM
Man this pc sucks Third Eye Hardware Q&A 7 14-01-2007 08:37 PM
Samsung Sucks! Help! mario_pant Hardware Q&A 9 11-03-2006 05:47 PM
Piracy Sucks , Originality too sucks vineet_rajput_grover Software Q&A 9 24-02-2006 04:54 PM
AOE 3 sucks usmayur Gamerz 3 12-09-2005 11:12 AM
