Old 30-08-2007, 03:34 PM   #1 (permalink)
Question Urgent Help regarding motherboard for E6750
Hello Friends,
Very soon i m planning to purchase a New PC but there is a problem.
My Budget for new CPU Box (processor+M.Board+RAM+SMPS+cabinet etc.) is around 20000 Rs. I am not able to spent more than 20000 this time so pls suggest me a good Motherboard with on board graphics so that if wish i can add graphics later and board should be compitable with below given Processor.
C2D E6750 - (4MB L2 cache 2.66Ghz 1333MHz FSB)
So pls suggest me a motherboard with or without onboard Graphics only in budget given above.
sainit is offline
Old 30-08-2007, 04:07 PM   #2 (permalink)
Default Re: Urgent Help regarding motherboard for E6750
integrated graphics is wot u want, den u hv no other choice but 2 go 4 de 965g chipset, otherwise 650i ultra is a gud option for overclocking,n is a very gud performer..
apacheman is offline
Old 30-08-2007, 05:14 PM   #3 (permalink)
XFX 650i Ultra is a good mobo at 5.5k, but it has no onboard graphics... You can add a 8400 based card for less than 3k... Otherwise, you can go for Intel DG33 motherboard, but I believe the onboard graphics are not as good as G965 based boards...
Arun
sakumar79 is offline
Old 30-08-2007, 05:26 PM   #4 (permalink)
thanks Friends,
I did some search on the net and i found another MotherbOard.
MSI P6N SLI Platinum (650i chipset based)
Pls tell me how is this board in comarison to XFX 650i ultra and what will the price i have to pay for this. Does it come with on board Graphics.
Thanks
sainit is offline
Old 30-08-2007, 09:10 PM   #5 (permalink)
Phalanx's Avatar
Actually its 650i SLI chipset. Anyway, its much better than the XFX one... But the price is more than double... Its very feature rich and you can check out the reviews in Tomshardware and Anandtech.com... I bot it 4 11.2K + TAX...Since your budget is 20K, I suggest you opt for the XFX one or maybe the Asus P5N-E SLI... And none of these boards come with onboard graphics...So u need to spend some more there...
C2D E4300, MSI P6N SLI Platinum, Transcend 2GB 667MHz, XFX 8600GT, Viewsonic VG1930wm, Seagate 250GB SATAII, Lite-On LH-20A1P, Compro VideoMate X50, Microsoft wireless KB and Mouse, iBall Grabit.....
Phalanx is offline
Old 30-08-2007, 10:16 PM   #6 (permalink)
moshel's Avatar
the onboard graphics of G33 based board is at par with G965 boards. intel 965 board comes for 7.2K. u cud try msi 965 round abt 6k with onboard graphics.
G33 board will come for arnd 8-9k. but is future proof as it supports DDR3 and 45nm processors.
moshel is offline
Old 30-08-2007, 11:05 PM   #7 (permalink)
well, Intel D965G is only around 3600/-.
Old 31-08-2007, 10:34 AM   #8 (permalink)
Thanks u all friends ,
I am still confused. But what i am planning now is :
CPU - 6750 - 8600 Rs.
M.B.- XFX 650i - 5500 Rs.
G.Card - XFX 8600 GT - 7000 Rs.
RAM - 1 GB - 2000 Rs.
Hard Disk - 160GB - 2000 Rs.
Guys pls tell me is this configuration ok and is it Future Proof ?
Can I improve this configuration by making any changes to this.
and
If Possible pls tell me How i could bring budget to only 20000 Rs.
Thanks
sainit is offline
Old 31-08-2007, 11:47 AM   #9 (permalink)
Phalanx's Avatar
1) Proccy is great...
2) Mobo is fine...
3) Dont expect much from the 8600GT, although DX10 compatibility makes it decently future proof in gaming... If u are a non gamer, then it is as future proof as you can get right now...
4) 1 GB ram is definitely not future proof...Min 2 GB is recommended... By the way buy 800MHz Transcend/Kingston/Corsair only...Prices are pretty low...
5)I would suggest u to go for 320GB hdd...Price diff b/w 160 and 320 is about 1200 bucks, so the latter is definitely more value ( also 160GB wont take much time to fill up if you are into gaming, movies and all)...
To bring the the total price under 20K, u would probably be better off with an AMD config:
Athlon 64 X2 5000+ --- 5-5.5K
ASUS M2A-VM --- 4K
Phalanx is offline
Old 16-09-2007, 01:16 AM   #10 (permalink)
I have my system based on C2D E4300, ASUS P5B-MX/wifi, Kingston valueram 1 GB DDR2-667, 400 W Powersafe SMPS. I use integrated graphics memory of 256 MB. My mobo(Intel 946GZ chipset) supports Intel GMA 3000 which has Pixel Shader 2.0, Vertex Shader 3.0 (software) & Open GL 1.4 and no Hardware Transform & Lighting. Can anyone suggest me of some good race & action games for my pc.
omdhar is offline
Old 16-09-2007, 02:37 PM   #11 (permalink)
Rebooting
Choto Cheeta's Avatar
You may take a look at there too, rather going for a New Thread http://www.thinkdigit.com/forum/showthread.php?t=66140
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 17-09-2007, 03:52 PM   #12 (permalink)
tech mighty
arun_chennai's Avatar
Get the following config
CPU - 6750 - 8k
M.B.- Biostar P35 - 5k
G.Card - Palit 8600Gt--5.5k
RAM - 2 GB -(Dynet)-2.6k (IT Wares)
Hard Disk - 160GB - 2.1k
arun_chennai is offline
Old 17-09-2007, 05:13 PM   #13 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
are you sure?
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 18-09-2007, 09:24 AM   #14 (permalink)
tech mighty
Originally Posted by The_Devil_Himself
are you sure?
yes yar...now the palit 8600gt is available for 5.4k and Ram price is at all time low now...
Kingston 1gb---1.4k
Transcend-----1.3k
Dynet----------1/1.1k
Old 18-09-2007, 02:56 PM   #15 (permalink)
thanks man.great news for me.
Old 18-09-2007, 03:42 PM   #16 (permalink)
Friends
Pls tell me Good motherboard with Onboard Graphics for E6750
and Later we can add graphics card to it according to our need.
Thanks
sainit is offline
Help with motherboard **URGENT** vineetrocks2005 Hardware Q&A 20 01-09-2007 10:39 AM
Intel C2D E6750--? iamitp CPU / Motherboards 1 26-06-2007 07:39 PM
[Urgent] Which Motherboard? vijayts CPU / Motherboards 6 06-09-2006 11:18 PM
Motherboard - Urgent help parimal_xp2003 CPU / Motherboards 6 24-06-2005 11:34 AM
