Old 30-08-2007, 09:48 AM   #1 (permalink)
Cool Problem with CD RW Drive
Hi
I got my computer after a period of 2 months. I am on Windows XP and I have a Samsung CD RW Drive.
When I started it up it went through detecting the CDRW Drive all over again, but it detect it as a SAMSUJ drive or something. Twiddling the cables got it to detect it as a SAMSEW drive or something, but it detects it as a CD Drive not as a CD RW Drive. When I check it up in the BIOS setting it comes as a CDRW Drive.
Whenever I put in any CD in the drive it comes up as a Audio CD with Track1.cda. Even a WIndows Bootable CD comes up in the same files.
I have tried removing the drives from the device manager and reinstalling them, but still the same issue.
Any solutions
Bellyz
bellyz is offline
Old 31-08-2007, 10:20 PM   #2 (permalink)
CA50's Avatar
Default Re: Problem with CD RW Drive
ur drive seems 2 b faulty go for lens cleaner, cable tweaking or can try firmware update
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
problem with Pen Drive blacklisted Hardware Q&A 10 30-10-2009 04:35 PM
Pen Drive Problem!!!!! The Nilay Hardware Q&A 10 09-06-2007 04:00 PM
my cd drive has a problem yogi23 Hardware Q&A 4 29-11-2006 08:51 AM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
