Hello Friends,
I have an old laptop of toshiba,
with 40 Gb HDD, which crashed, it shows xp F8 advance boot menu, but doesnt proceed further.
I tried all things,
It shows HDD in BIOS
98,XP And Vista setups detects it when CD/DVD boots,
But setup cannot continue [hangs]when it accesses HDD to check/format/ install
I deleted all partition from FDISK,
and then could not repartition in FDISK [error] or in OS setups[hangs].
and now i am on conclusion that i have to replace it with new one, mostly 80 Gb Seagate/ Samsung, [ Or do you think that it is still usable? ]
I can fully assemble PCs, done many times succesfully, but never tried on laptops,
So i worry if i can replace it on my own or have to go to dealer?
As it was an imported 2 yrs ago so without warranty, [I can dare 1 time
Should i open it and give it a try? As I think mostly it will be similar to PCs, as i assume,only smaller and compact design.
Or do u think it is well and good not to open it myself,
Pl help,
