Old 30-08-2007, 10:08 AM   #1 (permalink)
Fortuna Favet Fortibus
amandeep86's Avatar
Default System Restarts After Showing Error in Blue Background
I get the folowing error in blue background sometimes while working or even installing new windows.
I'm using Windows XP Pro SP2
I have latest drivers too.
The Error:
"A Problem has been detected and windows has been shut down to prevent damage.
DRIVER-IRQL-NOT-LESS-OR-EQUAL
If this is the first time you've seen this stop error screen, restart your computer.
If this screen appears again, follow these steps.
Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any windows update you might need.
Technical Information:
***STOP: 0x000000 D1 .......
***U Sbuha.sys - address F77B8DE2 base at F77B7000
Begining dump of physical memory
Physical memory dump complete
Contact your system administrator or technical support group for further assistance."
What's the problem with my Laptop?
No Body to Help me?
amandeep86 is offline
Old 01-09-2007, 08:27 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Compaq nx6320 Restart Problem with Error
please provide details of ur Hardware, as its a Laptop do mention the make and model... aslo mention if any hardware change u have dont upon it...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 07-09-2007, 09:43 PM   #3 (permalink)
amandeep86's Avatar
I found the problem & rectified it. It was my secondary RAM module who's lock was broken.
I'm using a Compaq nx6320 Laptop.
Thanks for your reply CHOTO CHEETA.
And have you gone through the 'BEAT THAT' section of digit last month?
Old 07-09-2007, 11:02 PM   #4 (permalink)
Rebooting
I dont remember that !!! so is it some thing I need to know ??
comming back to your problem... seems to be driver issue... !!! if possible run a Microsoft Update to scan and make sure you have all the lastest update and then after that use this bellow links to install upto date drivers and BIOS...
http://h20000.www2.hp.com/bizsupport...&swEnvOID=1093
rebooting
ChotoCheeta.com
Old 19-09-2007, 05:57 PM   #5 (permalink)
amandeep86's Avatar
I'm the winner of 'BEAT THAT' contest in August Issue.
Old 27-10-2007, 08:51 AM   #6 (permalink)
Default Re: System Restarts After Showing Error in Blue Background
The Error:
No Body to Help me?
plis help me.
i have installed a wrong flash in my bios (i think).
bcoz after i flashed my bios my laptop stop from responding.. what can i do to repair this? plis i need ur help.
sulognon is offline
Old 27-10-2007, 03:55 PM   #7 (permalink)
Which laptop,what bios? Plz give complete details.
Let there be music.....
sashijoseph is offline
Compaq presario V3000 problem Kaushal Hiwarkar Software Q&A 6 17-03-2010 11:35 AM
Problem with my Laptop (Compaq Presario C500) zegulas Laptops and Netbooks 1 13-03-2007 09:36 PM
Disk I/O Error Problem Godhatesusalllll QnA (read only) 1 04-04-2005 12:54 AM
