Old 29-08-2007, 04:07 PM   #1 (permalink)
Default how to install a new hard drive??
hi
i have a 80 gb seagate hard disk on which i have the OS partition and three other partitions
i wanted to install a 2nd hard drive samsung 40 gb pata and also partition it
please help me doing the above
beanstalk_230 is offline
Old 29-08-2007, 04:19 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: how to install a new hard drive??
just connect the 2nd hdd as slave and boot...
Pathik is offline
Old 29-08-2007, 04:54 PM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
HDD will be connected as these settings,
jumpers may be configures as this,
Note, that mainlly we use 6 pin drives
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 29-08-2007, 04:57 PM   #4 (permalink)
its a 6 pin hard drive saurav
so should i go for the DUAL SLAVE Setup as shown in the picture you posted??
Old 29-08-2007, 05:06 PM   #5 (permalink)
Rebooting
Yes... please do that !!!
rebooting
ChotoCheeta.com
Old 08-09-2007, 07:50 PM   #6 (permalink)
Exclamation Re: how to install a new hard drive??
but the hard drive did not show up in windows xp but yeah my motherboard did recognize it.... what to do??????????
Old 08-09-2007, 09:22 PM   #7 (permalink)
Rebooting
1st of make sure, that jumpers are right, http://www.chotocheeta.com/2007/08/2...using-jumpers/ after that if still OS (Windows) fails to detect it, then try this please Right Click on My computers, then select the option called Manage...
now at computer management, please navigae your self to Disk Management...
as its a new HDD, either you need to Partition and format the logical drives or if its a already partition HDD then you need to asign Drive Letter on each of them...
rebooting
ChotoCheeta.com
Old 10-09-2007, 04:08 PM   #8 (permalink)
tthxxx very much CC
dont install OS on flash drive/damn small linux corrupted flash drive vish786 Open Source 2 28-07-2007 05:29 AM
Why hard disk drive as removable drive? Sheik Rasheed K Hardware Q&A 6 25-03-2007 10:01 AM
Hard Drive toooo hard for 815 Sonu Yadav QnA (read only) 20 16-06-2005 03:55 PM
Hard Drive! Optical or Magnetic Based Drive Stitch QnA (read only) 1 30-05-2005 11:14 PM
Help Knoppix Hard disk Install technoteen QnA (read only) 3 07-12-2004 07:09 PM
