Old 29-08-2007, 12:32 PM   #1 (permalink)
lalam's Avatar
Exclamation Flash Drive Unmount Issue
I recnetly plugged my flash drive into a linux OS and due to some system unstability the pc got hang so i clicked on unmount and when the icon disappeared i plug it out of the pc though i was sceptical about it as clicking on unmount on the first attempt did bring the usb icon back like after a minute but i plugged it out anyways on the second attempt thinking all was fine. Also this happened while i and my friend were exchanging some mp3 files, both our usb drives were plugged in.
Now what happend is that whenever i plugged the drive into my windows OS it does open but i can't add a new file nor format it nor do anything with it. I tried unmounting it through the command prompt but no good. So is there anyway i still can get around this problem. Well i did have a thought about getting it replaced but will be glad if anyone here has a solution.
Thanks in advance.
lalam is offline
Old 29-08-2007, 01:29 PM   #2 (permalink)
Wire muncher!
infra_red_dude's Avatar
Default Re: Flash Drive Unmount Issue
download the hp usb drive formatting utility for windows from here: ttp://files.extremeoverclocking.com/file.php?f=197 and then try formatting ur usb drive from within windows.
infra_red_dude is offline
How to convert ordinary flash drive into U3 smart drive? thetopcyborg QnA (read only) 13 02-11-2008 11:59 PM
dont install OS on flash drive/damn small linux corrupted flash drive vish786 Open Source 2 28-07-2007 05:29 AM
Suse 10.1-How to unmount usb drive. No permissions? ilugd Open Source 6 29-11-2006 04:40 PM
Need some suggestions about buying Pen Drive(flash drive) ~It_is_Andrew~ Hardware Q&A 16 14-09-2006 10:23 PM
Diffrence between an usb pen drive & a flash pen drive? harpoon Peripherals 3 18-01-2006 11:25 PM
