Old 29-08-2007, 12:14 PM   #1 (permalink)
Default Netgear Wi-fi Router problem
Hi Guys,
I have Netgear WGR614v6 router for about a year and half.., Wifi was working fine until one day due to power surge the AC Adapter goes dead .
Can anyone let me know where I can buy a reliable 12V 1.5 A (DC-Output) power supply in Delhi NCR region. ?
I contacted Netgear India http://www.netgear.com/About/ContactUs.aspx
but nobody is picking phone.
Thanks
chits is offline
Old 24-11-2007, 05:42 PM   #2 (permalink)
!FREEWARES!
Akshay's Avatar
Default Re: Netgear Wi-fi Router problem
You can mail netgear and they will happily solve ur prb. Plus keep trying to call them. They will give you every bit of info. u may require.
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is offline
Old 24-11-2007, 11:04 PM   #3 (permalink)
Go to the shop where you bought the Router from. They'll surely help. Or just go to Nehru Place.
ico is offline
Old 24-11-2007, 11:16 PM   #4 (permalink)
anand1's Avatar
With the Voltage and the Current ratings you can search for the Supply Adapter in any of the computer peripheral shops.
Technology On The Fly
anand1 is offline
Old 24-11-2007, 11:23 PM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
Take any adapter with same current and voltage output rating.Nothing to worry about that.
ravi_9793 is offline
Netgear WG511v2 on Debian Issues sachin_kothari Open Source 12 28-06-2007 10:55 AM
Problem with dataone router keep_it_rl Hardware Q&A 11 15-12-2006 01:31 PM
