29-08-2007, 12:12 PM
I guess Corsair PSUs are overrated
U guyz wont beleive what happened today in the morning.i further oc my system to 3.24 Ghz and left the system to run with orthos stress test for whole nite.
in the morning what i see??
NVIDIA hardware alert that my gpu is not getting sufficient power????!!!!
7900 GT is not at all a power monger like the 8800 ones,i havent oc my system really high and dtill such a disgusting warning??!!
ny type of suggestions why this problem has occured are welcome.plz do reply.
my psu - corsair hx 620watt
DOTA is really addictive :D
29-08-2007, 02:26 PM
Re: I guess Corsair PSUs are overrated
Have you connected the 7900GT power plug to the PCI-E power slot on the PSU?
Q6600 G0 (TR Ultra-120), ASUS P5N32-E SLI, eVGA 8800GTX Superclocked (TR HR-03 Plus), Samsung 940BW, Corsair Dominator PC2-8500, CM Stacker 830, 700GB Storage, Corsair HX620W, APC Smart 750VA
29-08-2007, 02:56 PM
yup i have done that.my gfx card requires a 4 pin connector.
29-08-2007, 03:30 PM
So you have a 6-pin PCI-E to 4-pin adapter?
29-08-2007, 03:32 PM
actually i added a 4 pin connector,the pci-e 6 pin doesnt fit in my card.
29-08-2007, 03:39 PM
See that could be the problem. GFX cards are meant to be connected only using the PCI-E power ports from the PSU. Those are designed to meet the power requirements of the gfx cards. Just try and see if you can get a 6-pin PCI-E to 4-pin adapter so that you can connect your gfx card to the PCI-E power port on the PSU. I havent come across anything like this, but it may be available.
If Im not mistaken, you are using this? with a 4-pin connector?
http://www.extremetech.com/image_pop...d=93190,00.asp
Reason: Automerged Doublepost
29-08-2007, 03:52 PM
u are absolutely right.i am using that type of connector.so there s the problem??
nyway it didnt show underpowered untill i oc my system and stressed my cpu/ram with orthos.my NVIDIA pop up showed that gfx card is running in power saving mode.will that be a problem in running my pc as rite now i cant get a 6 pin to 4 pin converter and it will be foolish to try connecting the 6 pin plug to the 4 pin one  .
29-08-2007, 04:15 PM
Yeah thats the problem. The thing is that the other power ports on the PSU are not meant to power graphics cards and so it could be that your card is not getting the power it needs as other system components are drawing too much power.
29-08-2007, 04:32 PM
so wud it be a problem to run my pc for a while??
29-08-2007, 04:45 PM
No there wont be any problem as long as the load does not become too much.
