Old 29-08-2007, 11:19 AM   #1 (permalink)
Default nokia 5700 pauses while playing mp4 files
Dear All,
Kindly advise me as I have bought a semi-smartphone first time i.e. Nokia 5700.
Actually when I play mp4 files ( which are already bundled with the new phone) it works fine , but when I loaded new mp4 files from my pc, it plays this file with pauses, ( short pauses of 0.5-1 sec) . When I played the same file on nokia n-91, this works fine? whta may be the problem, as 5700 boasts to have RAM also. Pl guide me if it has some technical way out.
Regards,
Vivek
goelviv is offline
Old 29-08-2007, 11:28 AM   #2 (permalink)
AJJU
azzu's Avatar
Default Re: nokia 5700 pauses while playing mp4 files
its not the technical problem .....must be in software
I love and Live to Design
azzu is offline
Old 29-08-2007, 05:26 PM   #3 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
I actually have full movies in my 5700. Works perfect. Try converting movies using Total Video Convertor
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 29-08-2007, 05:37 PM   #4 (permalink)
Google Bot
Pathik's Avatar
dude dont create duplicate topics please...
btw how dae u call 5700 a semi-smartfone
Pathik is offline
Better?: Nokia 5700 or N70ME awestriker Mobiles and Tablets 20 22-08-2007 10:10 AM
A problem with the Nokia 5700 abhishekkulkarni Buying Advice 3 11-07-2007 10:26 AM
Playing Real files on Nokia 5200 the deconstructionist Mobiles and Tablets 2 04-02-2007 10:39 PM
playing files with DRM whoopy_whale QnA (read only) 2 01-02-2007 10:25 AM
Wanna know how to convert a 5700 LE into 5700 ultra ? regenade QnA (read only) 6 16-11-2004 11:36 AM
