Old 29-08-2007, 01:46 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Unhappy Usb mp3 player malfunction
I have a transcend usb mp3 player. t.sonic -610 1 gb, It used to work perfectly fine.. and my vista basic used to read it. however after probably not 'safely removing' once or twice.. it has stopped being read by my computer. it now says unknown drive. i tried to update the firmware with the software in the cd given.. but even that dosent detect the device. Also my player functions perfectly otherwise, charges and shows the ''data transfer' screen on it while connected..
do i have any remedy for this?
ps. i tried it other computers and securing the needed driver files.
chillnow is offline
Old 29-08-2007, 03:19 AM   #2 (permalink)
Nav11aug's Avatar
Default Re: Usb mp3 player malfunction
when u remove a USB device 'unsafe'ly ..u r screwing up the power circuit... so ... i think uve messed up... contact Transcend
http://www.last.fm/user/NOLFxceptMe/
http://naveendageek.blogspot.com
Back after a long time. And well, EndSems screwed up as usual :)
Nav11aug is offline
Old 31-08-2007, 01:21 AM   #3 (permalink)
Iv registered with them on their website.. transcendusa.com... I wonder if they have any representations in India..? i dont have any contact no.s...
Im in Jodhpur rite now..
chillnow is offline
Old 31-08-2007, 09:15 AM   #4 (permalink)
With the recovery software from the tsonic cd installed,press the play\pause button and hold it when you connect the 610 to the usb port.After a few seconds a dialogue should pop up indicating a device found in recovery mode or sth.If it comes up you're in luck and should allow you to reinstall the firmware.If not,then try contacting your dealer for warranty.AFAIK the online registration doesn't help(for us Indians).
sashijoseph is offline
Old 31-08-2007, 07:32 PM   #5 (permalink)
i dont knw abt the recovery software.. i think u mean the firmware update thing.. ya i tried dint work, thnks anyways. i bought it from nehru place.. that big shop which sells everythin.. cash to cash..somethin like that, delhites will know.. sigh.. will go in nov. but i believe they dont do the warranty service..they just give a bill and u have to approach the transcend ppl wid the bill and warranty card.
chillnow is offline
Old 01-09-2007, 12:47 AM   #6 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
my ipod had the same problem. They wld have replaced it as well(but didn't due to my stupidity). If its within warranty, ten they should replace it . Don;'t go telling them abt this safely remove thing. It will only give them a bahana.
jin files ka koi server nahi hota unka bittorrent hota hai
chesss is offline
Old 01-09-2007, 01:08 AM   #7 (permalink)
NP : Crysis
xbonez's Avatar
even i have a prob with same player. after around 30 secs of switching on, it shuts off. battery fully charged and always safely removed
xbonez is offline
Old 02-09-2007, 08:32 AM   #8 (permalink)
jatt's Avatar
i have a mp4 player but shows format error on some songs i have check the bit rate of that songs its same as another which are well played but i could't understand whats it please help me out if anyone experiences same problem here thanks in advance
ਨੋ ਗਰਲ ਫਰੈਂਡ ਨੋ ਟੈਂਨਸ਼ਨ,no girlfriend no tension,website: Punjabi.c-o.in,forum: punjabiteacher.co.cc
jatt is offline
Old 02-09-2007, 10:49 AM   #9 (permalink)
Nav11aug's Avatar
hey.. dnt the company websites provide any 'help/troubleshoot' sections
Nav11aug is offline
Old 02-09-2007, 06:25 PM   #10 (permalink)
ya they do and it dint help... most probably my mp3 player has an hardware problem.. and transcend do not exist in india.
chillnow is offline
Old 02-09-2007, 07:31 PM   #11 (permalink)
digiFriend's Avatar
if it is cheap chinese made then read the thread on this forum.
1GB pendrive reduced to 120MB on its own plz help me seriously
Check the following link.
http://mympxplayer.org/how-to-removi...ck-vt2400.html
you never know what you can do until you try
digiFriend is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/66772-usb-mp3-player-malfunction.html
Usb mp3 player malfunction Hardware Troubleshooting Question This thread Refback 01-12-2010 02:58 PM
CD Rom Malfunction harmads QnA (read only) 10 07-08-2007 02:50 AM
Usb Malfunction rithesh Hardware Q&A 3 12-02-2007 11:54 PM
Printer Malfunction HELP cosx Peripherals 2 18-05-2006 06:48 PM
sms tone malfunction gdatuk Mobiles and Tablets 4 18-10-2005 10:13 PM
