| Forum |
#1 (permalink) |
this is my first post..so if any error then pls tell... My problem is....i have IBM 2GB(2*1GB) PC2 3200 CL3 ECC SDRAM RDIMM 1.8V 3-3-3.... and i am going to purchase a new system with 2*1GB DDR2 667Mhz RAM.... My question is can i use both in one motherboard which have 4 DIMM slots(DDR2).. Secondly will all 4 run on individual speeds... Thirdly what does 3-3-3 and 1.8v means???? Thanks in Advance I mean can i use all 4 DDR2 RAM chips and would be wise to use it or not???
Radhesh A. Bhoot ---------------- Core-2-Duo E6750 @ 2.6GHz, Intel G33 Motherboard, 2GB@667Mhz, 1TB HDD, 550W PSU, ASUS EN8600GT, 19" SAMSUNG SyncMAster 920NW... I Am Lovin It..! Last edited by Radhesh Bhoot; 28-08-2007 at 11:22 PM. Reason: Automerged Doublepost |
#2 (permalink) |
Back to l33ching :)
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
^^u wont be able to use the IBM DDR rams since the new system supports DDR2 rams
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain |
#3 (permalink) | |
http://www.last.fm/user/NOLFxceptMe/ http://naveendageek.blogspot.com Back after a long time. And well, EndSems screwed up as usual |
#4 (permalink) | |
die blizzard die! D3?
Stealing your women and horses since 1843. |
#6 (permalink) | |
Radhesh A. Bhoot ---------------- Core-2-Duo E6750 @ 2.6GHz, Intel G33 Motherboard, 2GB@667Mhz, 1TB HDD, 550W PSU, ASUS EN8600GT, 19" SAMSUNG SyncMAster 920NW... I Am Lovin It..! |
#7 (permalink) |
then ull be able to use it, but all sticks will be running at 400 Mhz even if u use 667 Mgz new DDr2 memories.
I suggest either u keep the older PC 3200 DDR2 1GB 400 Mhz or a brand new 1Gb DDR2 667 Mhz or 800 Mhz.
G1: PII X4 B50 4.0 | TRUE 120*2 | TA790GXB A2+ | 4GB DDR2 GSkill 1200 | Audigy 2 | HD4870 | HEC 550 | MX 518. G2: AII 240 | M2N 68AM+ | 3GB| 8800GT | Zebby Plat 500 G3: XPS M1530 | FZ 16. |
#8 (permalink) | |
Radhesh A. Bhoot ---------------- Core-2-Duo E6750 @ 2.6GHz, Intel G33 Motherboard, 2GB@667Mhz, 1TB HDD, 550W PSU, ASUS EN8600GT, 19" SAMSUNG SyncMAster 920NW... I Am Lovin It..! Last edited by Radhesh Bhoot; 29-08-2007 at 11:54 PM. Reason: Automerged Doublepost |
#9 (permalink) |
Get transcent DDR2 667 1Gb for 1.6k or Transcent DDR2 1G 800 for 1.9k.
The latter is better nd has greater value for money. U can opt for Kingston also if transcent is not available.
#10 (permalink) | |
and all the other fellow members who had replied to my problem...
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| ddr2 667 mhz- overclocking problem? | iamitp | Overclocking | 17 | 28-06-2007 07:46 AM |
| Amd Sempron 64 Bit 3200+ Or Athlon 64 3200+ 939 Socket | ASH_DSG | Hardware Q&A | 4 | 10-10-2006 07:55 PM |
| OVERClocking OF AMD 3200+ ??????????????? | agasti | CPU / Motherboards | 2 | 03-09-2006 06:27 PM |
| AMD CPU SPEED 3200+ | jay4u | Hardware Q&A | 1 | 16-04-2006 10:34 PM |
| AMD Athlon 64 3200+ | navino87 | CPU / Motherboards | 15 | 05-09-2005 05:56 PM |
