Old 28-08-2007, 04:58 PM   #1 (permalink)
Question Alternative To A Laptop?
actually my financial condition is not so good , I cannot buy a laptop or so . now I use a celeron 2nd hand computer ( 733 Mhz ) on 810e motherboard . I dont do any heavywork just some unix level C programming . but sometimes I need to read ebooks on the move or so . I am looking for a pda type of device which is very less costly .
I just want to take soem data on the go , i will not do any heavy application .
I am looking for something which is very mobile ( say its like a digital pad )and it can do :
1. doc pdf reading
yes only one job .
can anyone here suggest me anything ?
dearkumar is offline
Old 28-08-2007, 05:18 PM   #2 (permalink)
M$™ Certified Spammer
entrana's Avatar
Default Re: Alternative To A Laptop?
u cud try windows mobiles like from hp
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Old 28-08-2007, 05:52 PM   #3 (permalink)
Maybe you should think of portable apps (U3 etc.) or some kind of portable desktop (like USB mandrive if you're into linux... you can even make a portable windows using PEBuilder).
if you are going to places with public computers its a good, nice, easy and a CHEAP way to move around with you're PC... only without a PC.
just a thought.
jonixks is offline
Old 28-08-2007, 11:36 PM   #4 (permalink)
digit i am thinking's Avatar
Go for moto rockr E6 it has Document viewer Feature.
You able to view MS Word, Excel, PPT, PDF
http://www.gsmarena.com/motorola_rokr_e6-1810.php
Or may be any windows mobile based phone such as HTC
digit i am thinking is offline
Old 28-08-2007, 11:42 PM   #5 (permalink)
Pawned!... Beyond GODLIKE
fun2sh's Avatar
just buy a simple java enabled color phone and USE READ MANIAC FOR READIN EBOOKS. Dwnld readmaniac from searchin in google. u just need to contest PDF and DOC files to TXT format then use READMANIAC to create a java applet and send that to ur mobile.
If God has indeed created Himself in His own image, then I submit to you that God is a cockroach !!!!!!!!
fun2sh is offline
Alternative to MS Paint Sridhar_Rao Software Q&A 24 02-03-2007 06:15 PM
VCDCutter alternative whoopy_whale QnA (read only) 10 24-01-2005 02:44 PM
