| Forum |
#1 (permalink) |
"A problem has been detected and windows has shut down to prevent damage to your coputer. If this is the fist time you have seen this stop error screen, restar your computer. If this screen appears againg folow theses steps: Check to be sure you have adquete disk space. If a driver is identifie in the stop message, disable the driver or check with the manufacturer driver update. Try changing video adapters. Check your hardware vandor for any BIOS updates. Display BIOS memory options such as cashing and shadowing. If you need to use safe mode to remove or disable components, restart your computer press F8 to select advanced starup options, then select safe mode." No I absolutely clueless. This is new mother so I why do I go for bios update. Does it requiere any additional driver for the hdd?? Pls help me. Thanks Sghosh |
#2 (permalink) |
I had also the same problem. Problem is with partitioning. I deleted all the partitions, re-partitioned the the disk again and formated the partitions. It worked. I used Norton Partion Magic.
#4 (permalink) |
Gizmo Freak !
U r using a non sp2 installation cd right ??????????
If yes then u need a sp2 integrated Win XP installation CD. Get one or make one using nLite slipestreaming and then try out. |
#5 (permalink) |
I presume you are loading the SATA drivers during installation of XP using the driver disk provided with motherboard.
Try creating a partition thru XP Install option and continue with installation. If it's thru and XP loads, then go to Control Panel -->Admin tools--> Disk Mgmt and decide further logical, primary partitions & formatting etc |
#6 (permalink) |
use SP2 ...no problems whtsoever and lookup Microsoft's Knowledge base ...will def help
http://www.last.fm/user/NOLFxceptMe/ http://naveendageek.blogspot.com Back after a long time. And well, EndSems screwed up as usual |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Help !! Error while installing.. | prateek_san | Software Q&A | 1 | 28-06-2007 08:12 PM |
| Error after installing IE 7 Beta | Manshahia | Software Q&A | 36 | 25-02-2007 08:15 PM |
| Installing XP NTLDR error | s18000rpm | Software Q&A | 29 | 05-02-2007 03:36 PM |
| Error in installing IE7 beta | choudang | QnA (read only) | 1 | 12-10-2005 09:01 PM |
| error installing firefox | vandit | Internet & WWW | 2 | 03-08-2005 06:06 PM |
