| Forum |
#1 (permalink) |
VIP / powersafe 500watt SMPS VIP / Powersafe 600watt SMPS i have googled as well as searched digit but in vain i wish to run two 8800 in SLI |
#2 (permalink) |
get Zeb 730 Diamond. Its proven much stable by CHIP mag. Its as stable as Antec Neo power or trio. And SLI sertified too
http://www.zebronics.net/zeb-730w-spec.asp
G1: PII X4 B50 4.0 | TRUE 120*2 | TA790GXB A2+ | 4GB DDR2 GSkill 1200 | Audigy 2 | HD4870 | HEC 550 | MX 518. G2: AII 240 | M2N 68AM+ | 3GB| 8800GT | Zebby Plat 500 G3: XPS M1530 | FZ 16. |
#4 (permalink) |
a.k.a Niks
well if ur running 2 8800s in SLI you oughta get a PSU with much more stable rails .. And IMO the Powersafe/Vip ones aint that stable and are just single rail ones...
Spend a bit more and go for a Coolermaster Extreme Power 500 or 600W if ur on a budget, it'll do u good.. Look here for a tiered rating of the various PSUs and see where Zebronics stands... http://www.xtremesystems.org/forums/...d.php?t=108088
.. E6750 2.66GHz|Asus P5W DH D'lux|2x1GB Kingston 667MHz|XFX 6800GS 512MB OC|Seagate 7200.10 320+250+250GB|Sony DRU-830A|Coolermaster 600W|Creative 5.1 T6060|Logitech EX111+G5|ASUS VW192T|Antec 900 .. |
#5 (permalink) |
Its mentioning bout normal CM nd Zebronics PSU.
CM's Extreme Power and Zeb Diamond 730 is as stable as the Antec or OCZ.
#6 (permalink) |
a.k.a Niks
Dunno abt that, not had any personal experience with zebronics, so can't comment much either.. But the CM Extreme Power being a Seventeam OEM and considering Seventeam's reliability I personally would go with it any day if i need a budget PSU..
Btw Oodibaba hasn't stated which 8800s he's planning to use in SLI.. If its the GTX(
#7 (permalink) |
^^Agreed but I dont think u can go abt comparin the Zebbys n Xtreme power with tha premium ones such as Antecs, corsairs...
@oodibaba- I jus know dat the Powersafe 600W has dual 12v rails havin 22A..
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630. |
#8 (permalink) | |
Why don't you allow HTML signature? |
#9 (permalink) | ||
BTW m getting the two EVGA 8800 GTS's (640MB) from US Quote:
********************************************* i wanted to know the ratings of VIP 500watt smps coz the coolermasters have 18Amps on each rail..so if VIPs have higher ratings then i would prefer those what say people and people please consider i ve 4 hardisks running on raid 0 and 2 optical drives and 4 fans running and ya forgot to mention powersafe VIP smps's have 3 year warranty Last edited by Oodibaba; 26-08-2007 at 06:44 PM. Reason: Automerged Doublepost |
#10 (permalink) |
@Oodibaba
ull need at least 650w PSU to support all dat loads. As u gonna get da card from US, why not get the PSu also from there?
#11 (permalink) | |||
a.k.a Niks
See here for more info on choosing a PSU .. http://forum.ncix.com/forums/index.p...t=36&subpage=1 (got this thanks to Eazy@TE)...
.. E6750 2.66GHz|Asus P5W DH D'lux|2x1GB Kingston 667MHz|XFX 6800GS 512MB OC|Seagate 7200.10 320+250+250GB|Sony DRU-830A|Coolermaster 600W|Creative 5.1 T6060|Logitech EX111+G5|ASUS VW192T|Antec 900 .. Last edited by Sylar; 26-08-2007 at 10:30 PM. |
#12 (permalink) |
ToTheBeatOfUrHeart
ooooff hoo,all u need is a true rated Corsair HX620w.It will be more than enough for ur need.It has 50amp of total current on the 12v rails and has two pci-express power connectors for SLI(theoretical output 900watt and real output 600watt).Its SLI certified and can support upto two 8800 GTX in SLI.Its efficiency is 85%.It costs Rs7,800 including tax and is available from tirupati enterprices.Close ur eyes and take it.For ur system this is what u need anything below just won't do justice.
Mobo - P5N32-E SLI,P5N-E SLI|GFX - 2x8800GTS,8800GT|Processor - E6550,E6600|PSU - CM EP 600,HX620W|Physics - 2x8600GT |
#13 (permalink) |
a.k.a Niks
^^^ exactly wat i've been wanting to say from the beginning.. but everyone's after powersafes & vips here...!!! btw Harvik the HX 620's price has dropped a bit .. can be got for arnd 7k depending in which city u are...
Edit : @oodibaba here's the review to help u out.. http://www.jonnyguru.com/review_details.php?id=32
#14 (permalink) | ||
+3.3V +5V +12V1 +12V2 -12V +5VSB 18A 12A 8A 13A 0.3A 2.5A dunno when kunhar last updated their site... and that comparision chart sucks its quite old Quote:
#15 (permalink) |
for calculating the required rating for PSU check out dis:
http://www.extreme.outervision.com/index.jsp and use the power consumption calculator nd post the result also. My power consumption at peak load is 610W according to da calculator.
G1: PII X4 B50 4.0 | TRUE 120*2 | TA790GXB A2+ | 4GB DDR2 GSkill 1200 | Audigy 2 | HD4870 | HEC 550 | MX 518. G2: AII 240 | M2N 68AM+ | 3GB| 8800GT | Zebby Plat 500 G3: XPS M1530 | FZ 16. Last edited by dOm1naTOr; 27-08-2007 at 12:35 AM. |
#17 (permalink) | ||
#18 (permalink) | |
ToTheBeatOfUrHeart
#20 (permalink) |
@Harvik780
nowadays some kingston memories [DDR2 667] comes with Hynix chips in it. They are no gud. Sure they have quality, but u can't oc them or optimise the latencies, but all transcent modules carry jetram chips, so gud OC is guarenteed. But Some Kingston memories are oc friendly.
G1: PII X4 B50 4.0 | TRUE 120*2 | TA790GXB A2+ | 4GB DDR2 GSkill 1200 | Audigy 2 | HD4870 | HEC 550 | MX 518. G2: AII 240 | M2N 68AM+ | 3GB| 8800GT | Zebby Plat 500 G3: XPS M1530 | FZ 16. Last edited by dOm1naTOr; 29-08-2007 at 11:47 PM. |
#21 (permalink) | |
ToTheBeatOfUrHeart
#22 (permalink) | |
so is this a overclockable safely ???
Sony Ericsson Flashing, Modding, Patching, Hacking And More ! http://www.akshayy.com/sonyericsson/ |
#23 (permalink) | |
ToTheBeatOfUrHeart
#25 (permalink) | |
ToTheBeatOfUrHeart
#27 (permalink) | |
ToTheBeatOfUrHeart
Tirupati Delhi Number- 01132608570 Site- http://www.tirupati.net/about.html U don't have to bother where they are,just where their vendors are. Edit:The numbers are not working now for Delhi and mumbai,for me,check it urself.
#28 (permalink) |
The No.1 Stupid
I know nothing about power supply/SMPS. I need a new one as old one seems to be damaged. I have D845GVSR and P4, 512 MB RAM,120 GB HDD , 17'' CRT monitor, 2600 watt speakers. Please suggest me a good power supply with all the specifications of power supply, I need to tell the vendor .
n00b forever... |
#29 (permalink) | |
ToTheBeatOfUrHeart
I could not find the specs but it should suffice.
#30 (permalink) | |
V.Prem Kumar |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Powersafe or APC? | apacheman | QnA (read only) | 1 | 19-08-2007 06:10 PM |
| Zebronics 500W SMPS. Is it a good SMPS. Advice needed. | Yoda | QnA (read only) | 4 | 13-11-2004 11:15 PM |
| PowerSafe 400 Watts SMPS vs. VIP 450-Watts SATA Power Supply | shyamthakkar | QnA (read only) | 2 | 28-10-2004 07:35 PM |
