Old 20-09-2007, 01:16 AM   #31 (permalink)
Default Re: Powersafe / VIP SMPS
Originally Posted by ~Phenom~
I know nothing about power supply/SMPS. I need a new one as old one seems to be damaged. I have D845GVSR and P4, 512 MB RAM,120 GB HDD , 17'' CRT monitor, 2600 watt speakers. Please suggest me a good power supply with all the specifications of power supply, I need to tell the vendor .
Most of SMPS with low budget with 400W Sticker in actual have near by 240w only. And as per my knowledge you reuires NET 275w-300W to run your existing system.
Cheaper onw is also good - but if your city have frequent eletricity problem than go with Good SMPS
Why don't you allow HTML signature?
Stick is offline
Old 20-09-2007, 02:23 AM   #32 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Smile Re: Powersafe / VIP SMPS
That's why I recommended him a zebronics and not a frontech and/or intex.
Harvik780 is offline
Old 20-09-2007, 08:38 AM   #33 (permalink)
assasin's Avatar
yeah zebronics 400w is a good psu.i'm using it in my rig without any probs.will get to test its true worth 2night when i get my 8800GTS 320MB.as .of now its running flawlessly.
@harvik780 the zebronics 400w (with 20+4 pin) comes for 450 bucks.
the specs r :
+3.3v -> 28A
+5v -> 30A
+12V -> 20A
-12v -> 0.8A
+5VSB -> 2A
assasin is offline
Old 21-09-2007, 01:22 PM   #34 (permalink)
DD3030's Avatar
Arrow Re: Powersafe / VIP SMPS
the specs r :
+3.3v -> 28A
+5v -> 30A
+12V -> 20A
-12v -> 0.8A
+5VSB -> 2A
You are running so much with just 400W normal SMPS? (for the rig mentioned in your signature) or is it Zeb Pure Platinum 400W?
Is Zeb 400W SMPS sufficient for X24200+, ASUS M2A-VM, 8600GT, 250Gb HD, DVDRW ? I know without 8600GT it is, but has anyone run this kind of system comfortably with 400W SMPS? We don't have any electricity problems in my locality.
Also, the normal Zeb cases come with 300W/400W SMPS, are these from VIP or Zeb? I had read somewhere these are of VIP... does anybody know among Zeb and VIP normal SMPS which one is better?
Therefore, enjoy as much as you can.....
DD3030 is offline
Old 21-09-2007, 03:53 PM   #35 (permalink)
assasin's Avatar
NOOOOOOOOOOOOOO........... not this present rig.this rig just blew out the Zebby 400w psu and i had to sent it for replacement.
it used to run my prev rig without any probs (its was a E4300 @ 3.2GHz and a XFX 8600GT the rest being same).so u'll be able to run urs without any probs.just check whether it has 20A in the +12v rail.its the same 400W psu that comes bundled with the zebronics case.
to run my present rig i'm getting the CoolerMaster 650W 2night and at present running my rig using 2 psus.
assasin is offline
Powersafe or APC? apacheman QnA (read only) 1 19-08-2007 06:10 PM
Zebronics 500W SMPS. Is it a good SMPS. Advice needed. Yoda QnA (read only) 4 13-11-2004 11:15 PM
PowerSafe 400 Watts SMPS vs. VIP 450-Watts SATA Power Supply shyamthakkar QnA (read only) 2 28-10-2004 07:35 PM
