Old 26-08-2007, 01:30 PM   #1 (permalink)
Question LG DVD Writer problem!!
Hi frnds
I am using a LG GSA H10A Super-Multi DVD writer for the last one year.
The driver was doing reading/writing problems without any hitch. But, it has suddenly stopped working. It doesn't read the cd/dvd when i put one in the drive. The green light nlinks for a few seconds and then everything's dead. Clicking on the driver icon in explorer shows no drive.(I have autorun disabled)
Can you please suggest a solution to me or I will have to take it to the service centre!!
rohitm_001 is offline
Old 27-08-2007, 07:29 AM   #2 (permalink)
Default Re: LG DVD Writer problem!!
It's probably a dirty lens.Try cleaning with a lens cleaner cd failing which you may have to open and clean it manually.Try getting a friend experienced at this.
sashijoseph is offline
Old 27-08-2007, 03:36 PM   #3 (permalink)
Thnks
I will try to locate a lens cleaner cd!!
Old 31-08-2007, 10:25 PM   #4 (permalink)
CA50's Avatar
is ur prob solved. i am worried coz i 2 hv a LG DVD writter
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 01-09-2007, 03:50 PM   #5 (permalink)
No my prob is stilll persisting. I haven't been able to get a lens cleaner cd till now. Though I will love to do the lens cleaning myself, but due to lack of time I have requested a mechanic to do it. He is due anytime now. I hope that it solves the problem otherwise
Old 01-09-2007, 04:07 PM   #6 (permalink)
slugger's Avatar
u called a mecanik 2 do d job
d00d, depending on wer u live, u shud get a lens cleaning CD even in a stationary shop (hell, even d grocery shop in my adj building stocks them)
will get 1 4 50 bucks
just pop 1 in and it will do d cleaninig
slugger is offline
Old 01-09-2007, 06:13 PM   #7 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
I would strongly recommend getting a new DVD writer.Don't waste money no mechanic et al.Also the lens cleaner CD seldom works on DVD writers.
New DVD writer costs just 1425(lg one) and 1600(liteon--the best one).
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 03-09-2007, 03:03 PM   #8 (permalink)
I haven't been able to get the cd -thats because of time. Actually, I m not able to come online 2 so the prob persists.
By the way, y'day was sunday. I should have done it!!
Old 11-09-2007, 11:42 AM   #9 (permalink)
I got a lens cleaner cd but the problem is still there. I think that the drive is not playing the cd at all. When i put in the cd, the drive light blinks few times n then abruptly stops, whereas in usual cases it blinks continuously until cd/dvd is read.
Old 16-09-2007, 10:41 PM   #10 (permalink)
Question Re: LG DVD Writer problem!!
I am also using GSA-H10A drive and I am also facing this problem...In my case I could see DVD videos but I am not able to open/see any data DVD's.
Any help shall also be useful to me.
Dongay Rajasekhar Panda is offline
Old 17-09-2007, 09:57 AM   #11 (permalink)
assasin's Avatar
try updating the drive to the latest firmware.
assasin is offline
Old 17-09-2007, 03:47 PM   #12 (permalink)
Updated firmware, cleaned the lens - no improvement.
I m gone!!
Old 17-09-2007, 05:55 PM   #13 (permalink)
slugger's Avatar
I m gone!!
well since u said dat u can c d LED blinknig, it mean dat d power cable is working is properly, no problem with that
i suggest dat u unplug d IDE data cable from the drive and den re-plug it
cud b bcos it not making proper connexion
or you cud also try connecting it to d IDE cable ur HDD is attached (just 4 checking if it wirkin or not , keepin dem both on d same channel is not advisable)
slugger is offline
Old 18-09-2007, 03:55 PM   #14 (permalink)
pushkaraj's Avatar
Arrow Re: LG DVD Writer problem!!
Originally Posted by slugger
or you cud also try connectinkeepin dem both on d same channel is not advisable)
cud u plz kindly mention the reason for advising him not to keep both devices on the same channel.
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness
Think of your 3 best friends. If they are OK, then it's YOU
pushkaraj is offline
Old 18-09-2007, 04:39 PM   #15 (permalink)
slugger's Avatar
u can use it no problem, but d optical drive performance, ie data transfer spped will take a hit when they are on the same channel
thingy is provided in d manual that comes with DVD writers
slugger is offline
Old 18-09-2007, 08:52 PM   #16 (permalink)
I have smae problem with my Sony DVD writter. Lens cleaning doesnot work. Is it because I migrated to Winvista. It was working with XP.
kranti is offline
Old 19-09-2007, 03:41 PM   #17 (permalink)
Norms Buster
Driver conflict is your issue.
VexByte is offline
Old 20-09-2007, 07:43 PM   #18 (permalink)
pushkaraj's Avatar
Thumbs up Re: LG DVD Writer problem!!
oh yes, now i remember that i once had two devices on one channel and at times when accessing the optical drive, my hdd activity used to slow down.
Old 28-09-2007, 01:09 PM   #19 (permalink)
now this is strange. i opened the dvd case and cleaned the lens, used a lens cleaner too but neither worked. so i took it to LG's service centre. the guy there checked it n told me i have got a lens problem (as if i didn't know)
i reconnected it just to give it a last try n now it can read CDs but cant copy anything frm it, DVD video too not working. can i have a driver problem as my LAN card too developed a snag which was corrected by reinstalling driver.
the writer is automatically detected so what can i do?
Old 28-09-2007, 06:21 PM   #20 (permalink)
No man it's not a driver issue.The lens is pretty much gone.
DVD writer problem... shyamno Hardware Q&A 8 03-04-2007 04:54 PM
DVD Writer Problem sagargv QnA (read only) 1 20-08-2006 07:42 PM
Writer problem. nevillle23 QnA (read only) 5 20-07-2005 12:22 PM
DVD Writer problem RaceDilepa QnA (read only) 8 21-12-2004 09:21 AM
